05-13-2002, 08:07 AM | #1 |
Advice with Pinion Nut
I pulled the pinion nut before reading any info about reinstalling. Now that I have it out without making any lineup marks, what should I do?
Please help........... Thanks
Ken Smith 99 C5 Torch Red Coupe 85 Chevy Candy Apple 70 Chevy 1/2 in process.Semi-gloss black powdercoated frame & suspension, disc brakes up front, 3" drop spindle(Beltech) 5 lug 3.73 rearend, ZZ4, Sanderson headers, 700R4, Air Ride system, Summitt 16 gal fuel cell, Holly mech. fuel pump, |
05-13-2002, 08:08 AM | #2 |
And yes the seal was leaking. So that need to be changed as well.....
05-13-2002, 10:55 AM | #3 |
tighten it down just until is no slop in the pinion and then turn about 1/4 turn, but dont smash that crush sleeve in there any more than it is now, you gotta be careful, or...
------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham current fleet: -71 C-10 350/CH465/3.07- basketcase, #1 -90 Cavalier 2.2L sky blue, a driver -84 Z28 5.0L/700R4/3.73 daily driver -84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2 -82 purple Trans Am, project #3 *Paint is overrated* © RSS Enterprises 2000 |
05-13-2002, 12:11 PM | #4 |
That should work pretty good the way that Fast 68 posted. If you do by chance get it too tight,you can pull the yolk,& add some shim(.030-.060) between the yolk & crush sleeve,then pull it up again. Also,I would use blue locktite on the threads. Good luck.....69longhorn.
http://community.webshots.com/user/hotrodhorn |
05-13-2002, 12:44 PM | #5 |
I have had real good luck using an air impact gun. You will need one just to get the nut off. Set the gun on low first then notch the force setting up until there is no slop in and out. Once you get the slop out then work on the preload. You want a little bit of resistance when you turn the yoke back in forth before the pinion contacts the ring gear.
Or Just put the impact gun on full and zap the nut tight……… :0) This has also worked for me.....
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
05-13-2002, 02:15 PM | #6 |
Thanks guys, I thought I had screwed up big time.
05-13-2002, 02:37 PM | #7 |
Check out the Engine and Drivetrain board. There are a few threads that go over pinion seals and such. Good luck.
------------------ 72 C-10 Custom Deluxe LWB, 2WD, 350 700r4, Holley 600 UNITED STATES ARMY - ALASKA "Rangers lead the way!, Medics bring them back!" |
