? for dropmember guys
yes i,ve seached. does anyone have pics of there braklines on the front after the dropmember installed thanks
nickle and dime |
Re: ? for dropmember guys
Have you searched? HAHA j/k I'm sure someone will chime in here. I don't have anything on the subject.....
67-72 parts collector,…
![]() Join Date: Nov 2002
I would imagine you're going to have to bend them up yourself. I don't think anything stock will work.
hey royo, I'll post some pics 2 morrow, it's kinda late, but if I remember right I didn't have to replace any lines just had to push and pull some.......
GROUND ZERO IS R LIMIT ![]() |
I have bent them up a couple ways:
I have ran them across the Dropmember just like on a factory 63-72 crossmember set-up... and I have ran them across the factory crossmember in front of the Dropmember (that's how the 73-87 lines are ran). It's a bit easier and less hassle bending the lines if you go the 73-87 way.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
OK then thanks guys. I dont care to replace them I just want to do it one time and be done
nickle and dime |
I had the lines routed like the 73-87's as mentioned but the frame is now stripped of all that stuff so I can't help w/pics. It did require tweaking the lines on the pass side to route through the frame braces.
