Old 12-29-2008, 08:46 PM   #1
DavidB
DavidB's Avatar
4l60e transmission/ shifter
I have a 6.0 lsx engine with a 4l60e transmission in a 71 manual truck. Right now it has a hurst floor shifter but I would love to move it to the steering colum to free up the floor space and look more original. Thanks for any sugestions.
DavidB is offline   Reply With Quote
Old 12-29-2008, 08:55 PM   #2
Gray Ghost
Gray Ghost's Avatar
Re: 4l60e transmission/ shifter
JUst out of curiosity, which floor shifter do you have [model number/name]? I am swapping in a 4L60E at some point and want it to be floor shifted.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 12-30-2008, 01:30 AM   #3
boostat4500
My burb was also an original 4 speed. I bought an auto column out of a 72' and bolted it in. Looks perfectly original. I run a straight rod down to the shift arm on the tranny, but you can also use the cable set-up. Is that the kind of info you're looking for?
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 12-30-2008, 02:01 AM   #4
Senator350
Senator350's Avatar
as long as we're suggesting things for YOUR truck, I'd like to suggest a retrotec or a shrifter... and make it look decent with a classic steering wheel.
PADDLE SHIFT FTMFW!
RN U OVR
Senator350 is offline   Reply With Quote
Old 12-31-2008, 11:19 AM   #5
DavidB
DavidB's Avatar
Got it from summit. HUU-3838504 PROMATIC 2 SHIFTER. Works good and looks sporty just wantiong something else. Hope that helps.
David
Old 12-31-2008, 11:21 AM   #6
DavidB
DavidB's Avatar
I think tat is what I'm looking for guess I'll try and find a auto column and go from there. Thanks.
Old 12-31-2008, 11:24 AM   #7
DavidB
DavidB's Avatar
PADDLE SHIFT FTMFW!
Yeah I'm up for any suggestions. But I don't know what a retrotec or a shrifter is.
Old 12-31-2008, 11:26 AM   #8
Gray Ghost
Gray Ghost's Avatar
Thanks David...that's pretty close to what I had in mind.
Kelly
Old 12-31-2008, 12:13 PM   #9
Helidoc
Helidoc's Avatar
Not to hijack your thread. Just another question concerning the swap. How do you get around the detent for the OD. With the standard 3 speed auto column.
68 C10 2WD 250 6cyl Clifford 4bl, Edl Carb, Headers, work in progress
Helidoc is offline   Reply With Quote
Old 01-02-2009, 12:15 AM   #10
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
I use the standard PRND21 and it works fine. D is Drive and the other 3 actually don't line up, but I don't mind. I have the regular tilt column from a 72 along with the factory linkage and a 4L60E.
low'n slow is offline   Reply With Quote
Old 01-03-2009, 05:03 PM   #11
Senator350
Senator350's Avatar
dear sirs,
retrotek:
shrifter:
RN U OVR
Old 01-29-2009, 11:48 AM   #12
gmc1971harwich
gmc1971harwich's Avatar
hhhmm cool idea where do i get one of these paddle shifters?? i have an 700r4 and was going to go with a manual column to avoid the frustrations of rebuilding my auto tilt column. are these shifters expensive?
gmc1971harwich is offline   Reply With Quote
Old 01-29-2009, 12:32 PM   #13
SactoJim
SactoJim's Avatar
Find an auto column, get a Lokar universal trans linkage, and then get an overdrive indicator lense from truckandcarshop.com (I'm sure other vendors have it as well).
Works perfect.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
