12-29-2008, 09:12 PM | #1 |
Not a truck question
Ok guys i know this isnt a truck question but everyone always seems to be full of helpful info on here. so here goes. my wife drives an 82 camaro z28. the other night on her way home she lost all her lights. i replaced the blown fuse, and now have every thing but head lights. can not figure out what is going on. i've replaced the headlight switch but i am not getting any power to my headlights. any help would be great. and sorry this isnt a truck question. at least its still a chevy.
DJ |
12-29-2008, 09:33 PM | #2 |
Tot Roddin'
Re: Not a truck question
Have you checked the grounds for the headlights?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-29-2008, 09:34 PM | #3 |
actually i havent. didnt think that would just cause them to quit all at once. but that might explain the blown fuse
DJ |
12-29-2008, 09:35 PM | #4 |
Resident of Here
Also, you might want to get your headlight fluid changed...
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck Last edited by thirdstreettito; 12-29-2008 at 09:35 PM. |
12-29-2008, 09:38 PM | #5 |
that darn headlight fluid i should of checked it right from the start.
DJ |
12-29-2008, 09:44 PM | #6 |
Tot Roddin'
And so you know I just got a deal on headlight fluid and blinker fluid for only $2.99. Also, don't for get the 710 cap either.
12-29-2008, 09:46 PM | #7 |
Tot Roddin'
I know this might sound stupid.... but did you check the bulbs? Maybe the bulbs were blown when the fuses blew...
I've learned to start with the easy things before you tear about the car and find a loose connection... don't ask me how I figured this out, or how many times it took me to learn this...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 12-29-2008 at 09:46 PM. |
12-29-2008, 09:48 PM | #8 |
i've already have the dash ripped apart, fuse box, loose. and just came inside im done for the night. as i walked in the door my wife asked me the same thing "did u check the bulbs". i hadnt but wen right back out the door and did they are good
DJ |
12-29-2008, 09:51 PM | #9 |
Tot Roddin'
I would have hated to see how long she would have rubbed you about it had the bulbs been burnt out...
12-29-2008, 09:53 PM | #10 |
thank god they were good. she wouldnt of quit rubbing my face in that one. especially since its her car i just finished this summer for her.
DJ |
12-29-2008, 09:58 PM | #11 |
Tot Roddin'
Were there any wires that were melted?
12-29-2008, 10:00 PM | #12 |
none were melted. but the fuse was black
DJ |
12-29-2008, 10:08 PM | #13 |
I had the same problem before because I installed a CD player and left the illumination wire out. It kept grounding out and popping the fuse.......
Sounds like you may have a 12volt grounding out somewhere....when you replace the fuse does it pop again? |
12-29-2008, 10:10 PM | #14 |
before i replaced the fuse i had not lights at all, now i have tail lights fog lights parking lights just no head lights and the fuse is still good
DJ |
12-29-2008, 10:40 PM | #15 |
"brand new second-hand"
I had a simular problem on my 67 Camaro-I had everything but no headlights-I replaced the switch-no fix. I accidently stepped on the dimmer switch and instant lights-I guess somehow I found a nuetral spot on the dimmer switch-I still have the same switch, I am just wiser about how it works!
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
12-29-2008, 11:11 PM | #16 |
Gone to greener pastures
Where? I'm almost out of both.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
12-30-2008, 12:28 AM | #17 |
Does the 83 have the multi function switch on the steering column that you pull to dim and bright the headlights? You might check that, sometimes the wires get bare from rubbing back and forth. Happened to me...
12-30-2008, 12:44 AM | #18 |
I'd def check that switch out, then I'd go for the headlamp relay
12-30-2008, 11:21 AM | #19 |
Check the dimmer switch too.
12-30-2008, 11:38 AM | #20 |
Countdown Survivor
Here's a link from thirdgen.org with the wiring diagram for a later model, should be the same as yours.
Hope it helps, if you don't have the diagram already. http://www.geocities.com/vtcamaro/Wire-Diagrams.html
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
