Old 12-30-2008, 10:19 AM   #1
NEVERENOUGH
NEVERENOUGH's Avatar
Spring?
Hello everyone I am looking at buying a 69 gmc 3/4 ton 4x4 in the upcoming week and have a few ?'s. First are the front leaf springs interchangeable from teh 73-87 chevy trucks. I have a set of 4 inch front springs in the garage and was hoping to use them. Also the truck is a factory 4 speed what tranny do you think is in it? And last for now what front differential is used it is a disk brake front end just not sure what one. Thanks and I will post the pics when we get it home
NEVERENOUGH is offline   Reply With Quote
Old 12-30-2008, 10:23 AM   #2
msgross
msgross's Avatar
Re: Spring?
I would guess a SM 465 tranny, dana 44 front axle... Not sure on the springs but I thought the fronts were longer in 73...
are you sure it's disk? someone might have swapped it. I didn't think disk should up until 70 or 71 but I might be wrong.... corp 10 bolt works as well...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-30-2008, 12:27 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Spring?
The later front springs are too long unless you move a shackle mount. Someone has swapped in a different axle as the 69 axle was not available with disk brakes. The transmission should be an SM465 - reverse is to the right and down.
Transfer case is probably the Rockwell T221.
Will be easy to confirm all of this once you post the pics.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-30-2008, 01:51 PM   #4
lowe137
lowe137's Avatar
Re: Spring?
i have a 68 suburban.. i used a 4 inch from a 78 truck.. they are longer but they worked... i put longer shackles on from autozone... and it moved my axle back about an inch... because of the shackles i have more lift in the front than the back... if i did it again i would use the right springs so the axle is centered in the wheelwell...
lowe137 is offline   Reply With Quote
Old 12-30-2008, 05:05 PM   #5
msgross
msgross's Avatar
Re: Spring?
FGB52 is will work as well....
http://www.diy4x.com/suspension.htm
The Garage:
Old 12-30-2008, 06:19 PM   #6
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Spring?
ive got those "wedges" helped alot when i put an add a leaf on..
got a lil mroe room showing where the driveshaft meets the t case.. but i still like it
and it works great huuge life saver
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
