Old 12-04-2002, 07:52 AM   #1
skyhawk1
skyhawk1's Avatar
Annoying Suburban problems
My 72 Suburban is my daily driver. Rides like a Cadillac. Here's the main problem. I put a HEI distributor in it in the Spring this year and it started great for about 6 months. Now, just about every morning it cranks but won't start. So I get out, raise the hood and tap on top of the coil with a small screwdriver handle (usually 2 taps) and it fires right up and runs and starts good all day. I've replaced the rotor button, dist. cap and even the ignition module once. The last time I replaced these parts it started good for about a month, now it's doing it again. Any suggestions?
"The World's a Mess"!
71 C-10
72 Suburban 2WD
Oceana, West Virginia
skyhawk1 is offline   Reply With Quote
Old 12-04-2002, 10:43 AM   #2
Yellow Cheyenne
Possibly intermittent connection with the power wire going to it? Try moving the wire rather than tapping on it to see if it will start. I also had a bad pickup coil once. It had a lot of play in it and would intermittently not run.
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
