Old 12-30-2008, 01:38 PM   #1
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Rally wheel backsaping and going to 17's
OK, so I've got the 17's that used to be on my 78 just laying around. Meanwhile, the skins on my DD are getting tired, plus I bent one of the wheels the other day in the snow. So, my thinking is that I need a wheel, and 4 new tires. As long as I'm buying tires, why not get tires and throw on the 17's?!! Easy decision, right?
OK, so here is the deal. My 17s have 4.5" backspacing and are 8" wide. Right now I'm running the factory rallies that came on it in '91, which i presuming are 8" wide. What would the factory back spacing on these be? I hoping they are the same, as I have no need to tuck the tires in anymore.
Also, what size / brand tire should I be looking at. I would like quality M+S tire, as I drive this truck year round here in Michigan, back and forth to work 50 miles a day, down dirt roads, two tracks, and in the snow and ice. I currently have 235/75/15 Nokian Vativa's which have suited me very well. They were brand new when I bought the truck and I was skeptical of them, but they have turned out to be a pretty decent tire. I would like to go slightly taller tires on the 17's.
thanks for the help!
chuck
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-30-2008, 02:24 PM   #2
Izzy
Trucker.
Izzy's Avatar
Re: Rally wheel backsaping and going to 17's
Most of the stock rallies are 15x7 with 4" of BS.
Izzy is offline   Reply With Quote
Old 12-30-2008, 02:40 PM   #3
smashingchuck
ok, so my 17's will work fine as far as the back spacing. thanks izzy!
so, what size tires then? It's stock height and I do not plan on lowering it.
78 Build Thread
4Runner Build
Old 12-30-2008, 03:12 PM   #4
joe231
joe231's Avatar
there are 6-7, AND 8" rallys, i believe
from what I've heard, 17" tires are limited on size, and more expensive that larger ones....dunno, that is just here-say
your 235/75/15's are @28.9 inches tall with a 9.25 cross section width.
a 255/50/17 would be 27" tall and 10" cross section width
a 255/60/17 would be 29" tall and 10" cross section width
a 255/70/17 would be 31" tall and 10" cross section width
so......
do you know how to figure tire heights and widths?
CHEVY ONLY
Old 12-31-2008, 12:26 AM   #5
smashingchuck
yep...
78 Build Thread
4Runner Build
Old 12-31-2008, 12:34 AM   #6
f.monroe
f.monroe's Avatar
Bridgestone makes a 255/6017 semi all terrain tire . I would look into that tire for what you need . It is a Bridgestone Dueler H/L Alenza . Looks like exactly what you need and a reasonably priced tire .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
