Old 12-30-2008, 02:04 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Fuel tank and sender differences
Lmc lists different tanks for 73-81 and 81-86 trucks, does anybody know that makes them different? or is the sender that is used that makes them diffrent? and is it possible to use the later style on a older truck and visa versa?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-30-2008, 02:14 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: Fuel tank and sender differences
I could very well be wrong but I think the fuel inlet are different sizes
ont_guy_38 is offline   Reply With Quote
Old 12-30-2008, 06:41 PM   #3
cochino12
cochino12's Avatar
If thats all it should be fairly easy to swap years right?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-30-2008, 08:19 PM   #4
87Bob
It's probably a E.P.A. smog rule change that took effect.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 12-31-2008, 11:55 AM   #5
cochino12
cochino12's Avatar
Anyone else?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-31-2008, 12:12 PM   #6
72gmcworker
72gmcworker's Avatar
For the tank as said the inlet is different and for EFI trucks the tank has a pan in it under the sender/fuel pump. Sender hole in tank is all the same through the years.
I would stick with proper years unless your changing from carb to EFI or in-tank fuel pump.
Use OEM O-ring on any replacement Sender units...they actually fit
'70 Pontiac Firebird Esprit
'72 GMC 2500
'90 GMC V1500
'94 Dodge Cummins 2500
'02 Dodge 2500 Quad Cab Long Box 4x4 gasser
72gmcworker is offline   Reply With Quote
Old 12-31-2008, 12:26 PM   #7
ont_guy_38
ont_guy_38's Avatar
Found this to confirm about the inlets other then that they are the exact same tank
GAS TANK 16 U.S. GAL. SHORT WB W/ SMALL NECK (CAN BE USED W/ DUAL TANKS) CHEVY/GMC P/U 73-81
GAS TANK 16 U.S. GAL. SHORT WB W/ LARGE NECK CHEVY/GMC P/U W/ SINGLE TANK 82-87; W/ DUAL TANKS 82-86
sorry about the caps I just copied it and pasted out of an online catalogue
Old 01-01-2009, 05:17 AM   #8
rfmaster
rfmaster's Avatar
20 Gallon Tanks
73-81
C/K Pickup; 20 Gal. DIM 56" x 14" x 11"; "SMALL FILLER PIPE 1-1/4" I.D."
Mfg: Spectra Premium; Mfg Part Num:GM1A; Hollander# HOL# 197-982
82-86
C/K Pickup; 20 Gal. DIM 56" x 14" x 11"; "LARGE FILLER PIPE 1-5/8" I.D.";NON EFI
Mfg: Spectra Premium; Mfg Part Num:GM1B; Holander Hol# 197-1329A/B
87-91
C/K Pickup; 20 Gal. DIM 56" x 14" x 11"; "LARGE FILLER PIPE 1-5/8" I.D.";EFI, with baffle
Mfg: Spectra Premium; Mfg Part Num:GM1C; Holander Hol #197-1417
Will Fit Various GM Applications (see lookup for exact application)
Happy New Year
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
