Another Day, Another Dollar
what to cut dash pannel with??
hey guys,
i've got airbags in the back of my '78 and i am putting in a compressor as well. I have my pump controls mounted on a checkered aluminum switchplate and i am going to mount it on the dash beside the headlight switch (no panel vents in my rig) my question is: what should i use to cut the hole in my dashboard?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Living Legend
Re: what to cut dash pannel with??
when we cut out my dash for the stereo we used a dremil tool and a high speed to cut space
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia.. ![]() project is temporarily on pause again... Thankyou wonderfull economy.. check it out Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap East Ok meet East Ok date Tony ![]() |
the pollock
yeap cut the dash foamy leathery stuff with a supersharp box cutter then cut the metal with a dremel
i used a flex shaft attachment so i could be mroe comfortable.. ive tried "tin snips" but i usually warp the metal support.. fine tune with a mild file and enjoy
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
what kinda bit did you use on the dremel?
the pollock
well the thin bits that come in the "combo pack" or whatever .. just plain suck
id reccomend using eyeglasses with those cause they snap and fly everywhere.. i use those metal cutting bits the caron fiber looking ones they cut right through that stuff and last a while.. so a cutting disc.. =-) just not the cheapy ones
It Is What It Is,,,,
If you have plenty of air supply you might be able to use one of these! I SO love mine:
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
Yeah, dammitmitchell and Mr79 got it down. The fiber reinforced dremel wheels are a product of perfection. Airsaw is awesome too, but I get 30 seconds worth before my 30 gallon craftsman kicks in.
G to the M to the C......fool! RIP Jerry Reed "The Snowman" |
One shot, one kill.
I generally use a die grinder with a cut off wheel, but you need lots of air to operate it. Even a 5 horse compressor needs "catch-up time". I have 2 5 horse compressors running in tandum so for me it's not an issue. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
