Old 12-30-2008, 09:50 PM   #1
70onB.A.D.'s
70onB.A.D.'s's Avatar
700r4 question.
What year model of the 700r4's can be bolted straight up to a older 350 and not have to have any of the 700r4 wiring to run it. It can bolt up just like a turbo 350 and 400.
70onB.A.D.'s is offline   Reply With Quote
Old 12-30-2008, 10:02 PM   #2
chevymad
Re: 700r4 question.
The 82-92's, but you will still have to hook up the torque convertor lockup wiring.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 12-30-2008, 10:06 PM   #3
BP68
BP68's Avatar
Re: 700r4 question.
IIRC Up thru the early 90's had a mechanical speedo, however, any 700R4 will need the TV cable for proper shifting. Also, even the early 700's used an electronic lockup. You will need to make a few connections to get this working properly.
Don't be intimidated, you will be very happy with the swap.
I am running a 89 Suburban 700 in my 68 with the stock TV cable and a B&M lock up kit. It includes all wiring and connectors, a speed sensor that runs off the speedo cable, and a small box with a knob that lets you "dial" in when you want it to lockup.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-30-2008, 10:23 PM   #4
70onB.A.D.'s
Re: 700r4 question.
Don't know where i can find one of those 700r4's do you guys. Also thanks for the help. BP68 Truck is looking great. What color blue did you go with?
Old 12-30-2008, 10:48 PM   #5
70clone
70clone's Avatar
Re: 700r4 question.
this is where i got my trans i got the stage2 and am very pleased it was 975 out the door with new tv cable converter and the geometry correction kit that hooks to the carb for the tv cable great bunch of guys
http://www.outlawtransmissions.com/
70clone is offline   Reply With Quote
Old 12-30-2008, 10:55 PM   #6
70clone
70clone's Avatar
Re: 700r4 question.
pic of my 700r4
i used the driveshaft out of a 1993 chevy 1500 that had a 700r4 its the perfect length the yoke to the old seal mark like it was factory you will need a cross joint so that the u joint will fit in the rearend not a big deal at all
