Old 12-30-2008, 11:32 PM   #1
stope4
Tach wire through firewall
I know this has probably been discussed but I have searched the site for two days can't seem to find the answer. I have a 71 and want to route the tach wire through the firewall. I know the hole is to the left of the bulkhead but I don't know what size hole I should drill. The Tach wire is from the typical tach wiring kit eveyone sells. Can someone answer this?
stope4 is offline   Reply With Quote
Old 12-31-2008, 12:23 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tach wire through firewall
Not off the top of my head. I just ran my wires yesterday but the hole was already there on mine so I didn't have a reason to check it for size. I will try and check it in the morning.
LockDoc
Leon
Old 12-31-2008, 06:20 AM   #3
JimKshortstep4x4
The hole size for the tach grommet is 3/4". Here is a pic of the factory hole.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-31-2008, 08:41 AM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
I just ran my tach harness wire a few weeks ago. I used Jim's picture as a reference and it was perfect! There will be a cardboard knockout you have to remove inside the cab as well. Then once the brown wire is through the bulkhead, it will run up to the plastic gutter, across the transmission tunnel, then down to the coil.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 12-31-2008, 11:22 AM   #5
LockDoc
LockDoc's Avatar
Jim
Thanks for posting that Jim... Saved me a trip to the shop. Now I can stay on the board longer...
LockDoc
Leon
Old 01-01-2009, 12:06 AM   #6
stope4
Yes Jim thank you very much. I plan to write the dimension on the tach page in my assembly manual since it references a page in UPC 1 that is not in the assembly manual.
Old 01-01-2009, 02:56 AM   #7
ERASER5
ERASER5's Avatar
Or you could use the factory wiring block. There are empty slots ready to use.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
