Old 12-30-2008, 11:46 PM   #1
tim21391
tim21391's Avatar
Anyone car for some rust??
i took off my passenger door to cut out rocker panels...got it cut and look what i found...let me know what ya think
the thing dangling is what is left of my inner rocker
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 12-30-2008, 11:49 PM   #2
chas350
Re: Anyone car for some rust??
looks better than my cab.....
git er done!
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 12-30-2008, 11:51 PM   #3
tim21391
tim21391's Avatar
i gotta order this piece that goes into the floor about 4 inches and then your inner rockers are already attached to it... it will be easier in the long run... and best part is the carpet will cover it...
Old 12-31-2008, 12:09 AM   #4
chevy29267truck
how come rockers go bad
chevy29267truck is offline   Reply With Quote
Old 12-31-2008, 12:17 AM   #5
tim21391
tim21391's Avatar
i live in kansas and they salt roads for snow so i guess its from that... and its been down some muddy roads... but its getting put back together just ordered the piece just now from wes over at classic heartbeat..so next week i will get to work on it again
Old 12-31-2008, 12:23 AM   #6
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
wow, I guess that explains all of the road noise!
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 12-31-2008, 12:40 AM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Yours is nothing compared to what I just found on my firewall and on my cowl and behind the fenders and...and...
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-31-2008, 01:07 AM   #8
tim21391
tim21391's Avatar
im hoping to get passenger side done within a week or two... (gotta wait on the outer floor extension piece) and since new years is coming im not expecting it soon... but once thats in im going to get other side done..do the same thing to that side... keep doors off...sand whole cab with 220 or so to knock off the first layer of paint....take windshield..and then prime the whole cab..then start working on the bed
Old 12-31-2008, 02:23 AM   #9
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Dude.....your rocker/floor area looks eerily similar to the one I just cut off my '67 GMC SWB yesterday! Check it out.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 12-31-2008, 03:34 AM   #10
sameyrasmea72
sameyrasmea72's Avatar
Salt has a lot to do with it, but I have seen alot of rusted rockers on trucks that have never seen salt. It is mainly because these drain holes get clogged up and nobody back then either took the time or knew to keep these drain holes clear. Getting wet does not cause rust, staying wet does.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-31-2008, 03:35 AM   #11
72truckman
72truckman's Avatar
Bad design with inadequate drainage... There is a really good article in FAQ:
http://67-72chevytrucks.com/vboard/s...d.php?t=201540
You can buy the whole inner rocker panel now (I wish they would've had the full piece when i did mine), but this gives you a good tutorial for the process
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 01-01-2009, 03:41 PM   #12
tim21391
tim21391's Avatar
so i need both pillars now right?
Old 01-01-2009, 08:03 PM   #13
lowriden58
lowriden58's Avatar
yup you will need both front and rear pillers, mine looked the same so i replaced them
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 01-01-2009, 08:14 PM   #14
BHRS
BHRS's Avatar
Man... I really feel for y'all with the rust. I am really lucky and fortunate to have a rust free '72.
When y'all get all the rust out, your trucks will be better than new. Good luck with all the work.
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 01-01-2009, 08:17 PM   #15
phipp13
THE DAMN YANKEE
phipp13's Avatar
good job but this is typical for these trucks mines worse. rust extends to the cab corners too and gotta replace the floorpans good luck
phipp13 is offline   Reply With Quote
Old 01-01-2009, 09:22 PM   #16
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
At least you can get rockers and floor pans and posts, etc. I have to contend with a used cab to get what I need, and it ain't nearly as simple as a rocker....Didn't have a clue as to how bad it was until disassembling it to finde out how bad it might be. I wasn't disappointed, just extremely discouraged. Still have to replace the rockers and lower front pillars.
Member Nr. 2770
Old 01-01-2009, 09:45 PM   #17
lowriden58
lowriden58's Avatar
Chevlo thats nothing some 16ga sheet metal cant fix! good time to shave the firewall
Old 01-01-2009, 10:26 PM   #18
10pointgmc
10pointgmc's Avatar
we put rockers in my 71 when i was 16 and i cut the inner rocker off completely and just welded braces up to the floor board in about three spots and they never did rust back out lasted atleast 10 years that i know of
10pointgmc is offline   Reply With Quote
Old 01-01-2009, 10:41 PM   #19
tim21391
tim21391's Avatar
got new corners sittin on the shelf next to my truck so there wont be a problem with rust there
Old 01-02-2009, 10:24 AM   #20
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
That's what I was shooting for, but what drove the original fix was when the wiper motor fell out of the cowl, due to the mounting rusting out. The guy who was working on my truck has lymphoma and I have another friend who is gonna replace the firewall with a donor cab that was rear-ended. He was just going to cut out the good sheet metal around the wiper motor for me, until the other guy got sick.
But, you're right. However, my intention is to refurbish my factory air and reinstall it. Don't have the do-re-mi to do an aftermarket a/c system.
Member Nr. 2770
Old 01-02-2009, 01:32 PM   #21
cobrajet21
cobrajet21's Avatar
tri-pro automotive sells the firewall replacement panel.
www.tri-proautomotive.com
cobrajet21 is offline   Reply With Quote
Old 01-02-2009, 01:36 PM   #22
cobrajet21
cobrajet21's Avatar
heres the link to the part.
http://www.tri-proautomotive.com/ser...and-toe/Detail
