12-31-2008, 01:08 AM | #1 |
Hard to start
I have a 1969 K/10 with a 350. When the truck is could it starts right up with one hit. I'll let her warm up and go a few miles. After letting it sit for a few minutes and i try to start it, it struggles. It starts better when it's cold. Any ideas?
1969 red k/10 with sb350 4.11 gear ratio, front disk, 3 speed automatic |
12-31-2008, 01:10 AM | #2 |
Re: Hard to start
i had a problem like this on my dads 67 mustang.. the electric choke was sticking shut
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
12-31-2008, 01:10 AM | #3 |
Re: Hard to start
havent fixed the problem yet..i just zip tied the choke open so whenever i wanna drive it i just gotta hold the gas til shes warm..haha
12-31-2008, 01:11 AM | #4 |
Re: Hard to start
it has a manual choke
12-31-2008, 01:13 AM | #5 |
Re: Hard to start
oh.. im not sure.. im just a 17 year old kid.. i dont know very much about engines unless the problem has happened to me
12-31-2008, 01:13 AM | #6 |
Re: Hard to start
sorry i couldnt help
12-31-2008, 01:16 AM | #7 |
Re: Hard to start
It's ok i'm the idiot that said fowled plugs haha
12-31-2008, 01:26 AM | #8 |
Re: Hard to start
do you think that your starter couldbe gettinghot while it is running.
12-31-2008, 01:27 AM | #9 |
Re: Hard to start
whats wrong with saying that?
12-31-2008, 01:30 AM | #10 |
Re: Hard to start
Thats ironic that you say that because my starter have out yesterday in a Safeway parking lot. It now has a brand new one in it and still does it; but maybe.
12-31-2008, 01:44 AM | #11 |
Re: Hard to start
Fowl is like chickens. Fouled is what plugs are.
12-31-2008, 07:48 AM | #12 |
Re: Hard to start
If you run headers on the truck, they go right near the starter solenoid. When it is cold it will start right up. Once the engine gets warm, the starter solenoid would be getting cooked for lack of a better word. You can go to the local auto parts store and for around five bucks buy a cover for the solenoid. Look in the Help section. If they don't have it they can order it for you. There should be a catalog there with the part number. You put the cover over the solenoid and it will deflect the heat. I have had this problem with all my cars and trucks that have headers and a Chevy V8.
Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
12-31-2008, 11:57 AM | #13 |
Between Trucks...
Re: Hard to start
If it's the starter solenoid getting too hot, I've had good luck with wiring in a remote Ford style solenoid.
Beat it to fit, Paint it to match... |
12-31-2008, 12:11 PM | #14 |
Moderator
Re: Hard to start
If you got the $$$, a high-torque mini starter is the way to go.
1. weighs 8 lbs vs. 30 lbs. 2. header clearance 3. no heat related issues 4. sounds sweeet when it cranks! |
12-31-2008, 02:59 PM | #15 |
Re: Hard to start
Thats the one i already have, the gear reduction one. For some reason the standard Chevy one wouldn't fit.
12-31-2008, 03:02 PM | #16 | |
Re: Hard to start
12-31-2008, 03:09 PM | #17 |
I wish I was a cowboy
Re: Hard to start
You say it starts better cold....meaning it cranks better cold? Just so we're tracking the right problem here - you do mean there's an issue with cranking, right? Otherwise, if cranking is good but it won't light when it's warm, different set of possible problems.
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
12-31-2008, 03:32 PM | #18 |
Re: Hard to start
If it is a cranking problem, then on my '69 350 It means my timing is a tad too far advanced. If I retard it a couple degrees it cranks and starts real easy when hot.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
12-31-2008, 04:56 PM | #19 |
Re: Hard to start
easiest and cheapest first step would be to pull clean and gap the sparkplugs
12-31-2008, 05:17 PM | #20 |
Old Skool Club
Re: Hard to start
...and if cleaning/gapping the plugs doesn't fix it, and since you said it has headers, then I'm gonna say (to reiterate someone else) that you will do a lot better if you install the heat shield on the solenoid. Granted, you could just install a Ford solenoid, but it would be easier to put the shield on the sol. When I changed carburetors on my engine, the new one (an Edelbrock Q-Jet) was so much leaner than the old AFB-type Edelbrock,that my truck was hard to start when it was warmed up. Installing the shield did the trick. It has NEVER failed to start since then. They're cheap and your labor is free. Just do it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-31-2008, 09:06 PM | #21 |
Weldin' it up
Re: Hard to start
i did this on my truck, its a lot easier, and if you ever have to remove the starter all you have to do is unbolt one wire from the solenoid and drop the starter rather than messing with all those little wires
-Paul- RIP El Jay Dirt is for Racing, Asphalt is for Getting There If need be, send me an e-mail at cbm_racing_90@hotmail.com 1970 Custom/10 LWB 4X4 350/TH350 2003 Silverado 1500 Ext. cab 1974 Kawasaki 175 F7 Enduro 2002 Polaris Edge X 700 |
12-31-2008, 09:37 PM | #22 |
Eat My Rust
Re: Hard to start
I put head shields on teh starter and solenoid on my truck. The Heddman headers were just too close. Just cut them out of aluminum sheets, bent tabs over on each side, and used hose clamps to attach it to the starter and solenoid. No problems yet besides a carb running stupid rich sometimes.
01-01-2009, 04:56 AM | #23 |
Re: Hard to start
Thank you for the input. It cranks fine, it just has a hard time starting.
01-01-2009, 09:10 AM | #24 |
Re: Hard to start
Check your timing,it could be advanced too far.
01-01-2009, 10:16 PM | #25 |
Re: Hard to start
It's at 8 degrees.
