______________
![]() Join Date: Sep 2006
Chevy 6 Lug Hub for MII Spindle
I came across this guy's Myspace page tonight and wanted to pass it along. A pair of 6 lug hubs with some pretty trick dust caps for $495.
Scroll halfway down the page for the hubs... http://www.myspace.com/sellersequipped |
Re: Chevy 6 Lug Hub for MII Spindle
nice looking do you know
if the track is pushed out further with the adapter it has on it. Justin www.scottshotrods.com |
#3 | |
______________
"My hubs ,there are no adapters, there is a steel face plate that sites flush on the face of the hub, you can not bolt a steel rim to aluminum hub. There fore i use a 3/16 steel plate that is flushed in the face of the hub, my hubs are exactly the same as a willwood, just mine hold a 6 lug pattern and there not a 2 peice hub, its a one peice & stronger. you need to use the Willwood Rotor and calliper and caliper bracket to complete the kit." I hope this helps. |
