Old 12-31-2008, 02:38 PM   #1
BradE
yard boy
BradE's Avatar
Rear suspension leaf to coil swap?
I've got a '71 GMC rear leaf suspension and I would like to swap the entire rear end with '72 Chevy coil suspension rear end. The GMC is a swb and the chevy is a lwb. Is this swap possible? Does the wheel base come into play? Any comments, pics, encouragement welcome! Happy New Year!
1984 Chevy c20
BradE is offline   Reply With Quote
Old 12-31-2008, 03:15 PM   #2
kcjones
I wish I was a cowboy
kcjones's Avatar
Re: Rear suspension leaf to coil swap?
Here's the quick snapshot:
1) no difference in swb vs lwb trailing arms, trailing arm crossmember, shock mounts, springs, spring cups, etc.
2) Biggest job is gonna be getting the leaf perches off the frame, and the trailing arm cross member into the frame.
3) Buy the extreme drop cross member from ECE! You'll get the exhaust holes already drilled.
4) make sure you check your trailling arm cross member for cracks, bends, etc. They take a tremendous amount of the forward acceleration load, so they can become weak.
5) Make sure you get shock mounts, xmember, trailing arms,shock mounts, panhard bar, panhard bar bracket, ubolts from the parts truck.
I'm sure the other members can add a lot of information to mine!
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 12-31-2008, 03:22 PM   #3
BradE
yard boy
BradE's Avatar
Thanks for the reply kc, good stuff!
1984 Chevy c20
Old 12-31-2008, 03:25 PM   #4
Peter82
Everything is Custom
Peter82's Avatar
Well anything is possible with enough money. But the first thing that comes to mind would be to buy a rolling frame with coils. This would allow you to re-finish the new frame then swap parts. You could even lower it to where you want it. Then switch over the front clip, engine & parts, the cab and bed. It sound like a lot of trouble but it can be worth it. Or... you can go to a junk yard and cut out the pieces from an old truck like mine, 1971 c-10 short bed. and then cut and weld on your frame. Then you have to cut and weld on your rear axle, and you will need upper and lower a-arms for the front. A LOT of cutting, welding, then grinding the welds down for a clean look. Then you will have to use chassie black or prime and paint the frame so it doesn't rust on you. A rusty frame is not your friend. And if you use the first way then you can replace all your body mounts and re a line your body lines.
Peter82 is offline   Reply With Quote
Old 12-31-2008, 03:27 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
I thought the frames on GMC leaf spring and Chevy Coil spring trucks were different over the spring area. So you wouldn't have a place to mount the Coil to the frame. I may very well be wrong on this.
dwcsr is offline   Reply With Quote
Old 12-31-2008, 04:00 PM   #6
SCOTI
SCOTI's Avatar
1/2 ton 2wd frames are the same for coil & leaf applications. The leaf frames do have extra 'beads' pressed into the framerail to increase strength @ the spring hanger area.
Leaf frames also have the trailing arm c.member w/o the trailing arm mounts (it's used for the carrier bearing support).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-31-2008, 04:05 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
PM Sent, Happy New Year
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-05-2009, 02:57 PM   #8
kcjones
kcjones's Avatar
...and the coil trailing arm mounts are just riveted on to the crossmember, right, so you could, for the sake of argument, simply remove the mounts from the donor truck and install on the leaf crossmember, right? Hence saving removing your original crossmember, which would be quite a time saver!
-Kris
Old 01-05-2009, 04:13 PM   #9
truckintexas
This will undoubtedly get a few responses, but here goes.........I have owned and driven both leaf spring (1 SWB & 1 LWB)and coil spring (1 SWB) trucks. IMHO, the leaf spring trucks performed better. My application was mostly everyday driving (some country roads), light-medium loads in the back, and an occassional boat or trailer attached.
However, neither of my coil spring trucks had a rear sway bar (which would have helped tremendously with loads, especially in corners).
truckintexas is offline   Reply With Quote
Old 01-05-2009, 04:28 PM   #10
BradE
yard boy
BradE's Avatar
Thanks for the replies! I'm in between trying to save money and swap a lwb '72 coil rearend into my swb '71 GMC leaf spring or bite the bullet and get the lowering leaf springs from ECE. I already have the '72 parked in the yard, so that's the tempting part. Looking at the scope of the project though, I may just have to save up and buy the lowering leafs when I can. Decisions, decisions..........
1984 Chevy c20
Old 01-05-2009, 04:28 PM   #11
SCOTI
SCOTI's Avatar
My 68 w/trailing arm suspension rides much better than my 74 does. Both are dropped @ least 5/7 (the 68 w/rear air bags).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-05-2009, 05:02 PM   #12
yellowGT
yellowGT's Avatar
i have a question and I apologize for asking on someone else's thread (bradE)but where do you find the panhard bar bracket? I have seen the weld on brackets but there is one that bolts up to the housing cover. Comes with longer bolts to bolt down the cover and the bracket. I saw it in a mag. but dont remember which.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 01-05-2009, 05:39 PM   #13
SCOTI
SCOTI's Avatar
ART (air ride tech) sells a billet alum Panhard bar bracket that attaches to the rear cover area. Other than that... I've seen them for F##d rearends, but no GM rear ends.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-05-2009, 07:06 PM   #14
BradE
yard boy
BradE's Avatar
No problem YellowGT, isn't that what this board is here for?
1984 Chevy c20
Old 01-06-2009, 01:00 AM   #15
yellowGT
yellowGT's Avatar
Thanks Scoti, im going to make a call and find out the price cause they dont list it on the website.
BradE-I agree but i do apoligize, who knows though you might of needed that answer down the road anyways.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 01-06-2009, 08:10 AM   #16
70GMCer
70GMCer's Avatar
Just a thought, but why not just do a "Flip Kit" on the springs you now have. I think that gives you a 5" drop, & most on here say that a "C" notch is not needed on the frame.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-06-2009, 09:10 AM   #17
lofly'a
lofly'a's Avatar
did'nt see it mentioned in anyone's posts, but the trailing arm crossmember is already on the trucks equipped with leaves. i have a 71 swb gmc with leaves and it has the trailing arm crossmember from the factory as have others that i have seen. check yours BradE, bet you'll find one under there.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 01-06-2009, 11:20 AM   #18
kcjones
kcjones's Avatar
As SCOTI mentioned, the xmember is there, it likely doesn't have the trailing arm mounts, though. Not terribly difficult to install, I can't imagine.
YellowGT: Depending on price, you'd be better off getting a custom panhard bar and bracket from ECE or CPP. That would move the rear end bracket to the passenger side trailing arm, instead of the pumpkin. Better geometry for the panhard job, anyway, and having the adjustable panhard is a must for lowering more than an inch or two.
I think the biggest difficulty with the leaf/coil swap is getting the leaf brackets off the frame nicely, but it isn't impossible.
As far as performance, it's hard to argue one's experience, but theoretically speaking, trailing arms are a superior design for cornering sway and acceleration (less bounce), but hauling/towing? Maybe leafs...
-Kris
Old 01-06-2009, 02:40 PM   #19
SCOTI
SCOTI's Avatar
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-06-2009, 03:21 PM   #20
Red_Rooster
Sorry for the Hi-jack, but have another related question. I know that the GMCs are typically leaf, as I had a SWB GMC with leafs. That truck was stolen. Now I have a 72 LWB Chevy...with leafs. How common was that? I thought all Chevys were Coil? It rides much smoother than the SWB GMC..maybe the added weight of frame and Bed make for the smoother ride??
~Travis
Red_Rooster is offline   Reply With Quote
Old 01-06-2009, 05:13 PM   #21
kcjones
kcjones's Avatar
~Travis
Leafs in Chevy's are more common than you might think. There's a rear end shop near me, and the guy has been building rear ends for over 30 years, and told me it was relatively common, maybe 5% of the 67-72s (that's like 150,000 trucks!) could've come with leafs. It was a normal factory option, and likely zero cost as leafs are cheaper to produce.
I don't know if there is a difference in ride "quality" between SWB/LWB? I guess if the spring is rated the same, and there's a little more weight, there would be slower spring reaction on bumps, but maybe they would handle worse (sway more) than SWB? Maybe it's just that it feels better because the driver is physically further from the point of suspension in the rear. Or, LWB drivers are just easy going guys that don't take bumps in the road to harshly?
-Kris
Old 01-06-2009, 05:31 PM   #22
grancuda
grancuda's Avatar
LWB's are smother riding than SWB's because of the wheel base and they are somewhat heavier, reguardless of coils or leafs
grancuda is offline   Reply With Quote
Old 01-07-2009, 11:15 AM   #23
gringoloco
A guy with a truck
gringoloco's Avatar
I did my pickup. It was pretty easy. Plan on spending an entire weekend if you clean/paint while you're in there...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-07-2009, 11:29 AM   #24
nicolas72gmc
nicolas72gmc's Avatar
I will let you know what the new leafs feel like when I get mine installed.
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 01-07-2009, 11:54 AM   #25
kcjones
kcjones's Avatar
Gringo, you did the coil swap, painted, notched, installed bags/compressor/valves/lines, all in a weekend? Was it a rear end swap or did you also remove leaf pads, install coil pads, weld and paint, too? If so, don't ever charge anyone for your work buy the hour, make 'em pay for the job!
-Kris
