Old 12-31-2008, 09:47 PM   #1
bsgmcc20
Im afraid of purple hangers..
bsgmcc20's Avatar
What CFM is this carb?
I am looking all over the net for info. found its a 1970 Rochester quad but not what cfm it is.
numbers are below
7040206 1 F
22091
any help? 750 or 800?
This is off a Bone stock 396 three speed auto with a non posi
bsgmcc20 is offline   Reply With Quote
Old 01-01-2009, 09:00 AM   #2
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: What CFM is this carb?
I have No Idea but heres A bUMP--^
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 01-01-2009, 09:30 AM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I found a 7040200 that is correct for 1970 396-400-454 for passenger car, vette, camaro, nova, & monte
They do not list the CFM but normally the BBC units are the higher flowing units
I also found a 7044206 which works for a nova or vette in 74 with auto - that would be a smaller cfm card
You should be able to find a 4 diget date code stamped into the base of the carb on the throttle lever side near the back bolt hole
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-01-2009, 11:48 AM   #4
neonlarry
neonlarry's Avatar
Do you have the carb? If so here is a pic of the difference:
http://dyeager535.topcities.com/qjetidentify.html
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-01-2009, 12:08 PM   #5
suville
suville's Avatar
Most Q-jets are 750 cfm some Buick and Cads ran 800 the link neon sent shows the difference
suville is offline   Reply With Quote
Old 01-01-2009, 07:44 PM   #6
Jokers69
Active Member
Jokers69's Avatar
There is a decoder
Rochester Number decoding
Example: # 7028219
DG 1938
7028219
Prefix code. "70" will appear on all late '60's Rochester Carburetors.
76 and later will start with "170"
2 - Decade produced.
702 - 1960's
703 - 1060's with A.I.R.
704 - 1970-1975
1705 - 1976-1979
1708 - 1980's
7028219
Year produced.
8 = 1968
If the number was 7045219 then
5 = 1975
7028219 Model
0 - Monojet (1 bbl) Federal standards
1 - Two jet (2 bbl) Federal standards
2 - Quadrajet (4 bbl) Federal standards
3 - Monojet (1 bbl) California standards
4 - Two jet (2 bbl) California standards
5 - Quadrajet (4 bbl) California standards
6 - VariJet (2 bbl) Fed
7028219 - Division.
0, 1, and 2 all indicate Chevrolet.
4 - Buick
5 - Olds
6,7 - Pontiac
7028219 - Transmission
Even numbers - Automatic Transmission
Odd numbers - Manual Transmission
DG Production Plant Code.
1938 Date Code
193 = 193 rd Day of the year
1938 8 = Year
Jokers69 is offline   Reply With Quote
Old 01-01-2009, 10:36 PM   #7
bsgmcc20
bsgmcc20's Avatar
Thanks for all the input.
The "bump" is what i need to look for. The Holley i have on it is a 650 off my other 72 with a 400sb. I was doing research on the quad and wanting to rebuild it and keep it orginal as much as i could. The Molding was damaged so that is the only casuality as of yet.
My idea for paint is white top with British racing green bottom.
http://fyi.gmblogs.com/2007/04/from_...ve_1970_2.html Here is a GM photo of the color idea
The green for the bottom
http://www.teglerizer.com/mgcolors/ Dark British Racing green Paint code PPG 9767
Old 01-02-2009, 02:43 PM   #8
neonlarry
neonlarry's Avatar
If you are looking for one, I have had good luck finding them on older caddies at pic & pull. Also look for one with an electric choke. And I would plan on a rebuild including rebushing the throttle shaft (possibly even changing the throttle shaft depending on linkage setup).
Old 01-02-2009, 03:22 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Jokers69....what a nice thing to post. I had seen that info before, but my damaged brain didn't dig it out of the annals of time, where it was buried. So, it looks like a 1970 Chevy Q-Jet for an automatic, without saying which engine it was on.
Member Nr. 2770
