01-01-2009, 12:53 PM | #1 |
Junior Member
bags will not air up.
I asked one of my techs to pull my truck in last night before he left the shop...he called me only to say that the readout for my bags said (0) all all corners, that he did not hear my compressor turning on, and that the switches were not working. The truck is stuck in full drop. The system is air ride tech...does anyone have any ideas where I should start...or what could have happened?? It was very cold today if that helps.
going to sell this one...looking for a SWB project next. |
01-01-2009, 01:09 PM | #2 |
67-72 parts collector,…
Re: bags will not air up.
PM Tony or one of the other Air Ride Technologies guys.
01-01-2009, 01:16 PM | #3 |
WTB this ad
Fuse blown for your switch box? If it's blown you aren't going to get a signal to the switches. In turn the compressor wont kick on due to it not having had a load put on it. My gauges only read when there's air in them, since you're aired out they should be on 0. Of course if the fuse is blown you probably have a shorted wire somewhere.
01-01-2009, 02:56 PM | #4 |
Junior Member
If the fuse is blown...wouldnt it cut power to the readout screen to? (I can see the readout)
01-01-2009, 03:12 PM | #5 |
WTB this ad
No idea....mine has manual gauges.
01-01-2009, 03:32 PM | #6 |
Verify the compressors have power going to them.
01-01-2009, 05:30 PM | #7 |
One day...
Process of elimination.. Whats getting power and what isnt, should be able to track the problem down. Im sure you have a fuse to the compressor too.
01-01-2009, 05:47 PM | #8 |
Junior Member
will do. I will check when I get to work in the am. Thanks guys.
01-01-2009, 06:17 PM | #9 |
Happy to be here
I'm going to guess that you have a fuse blown to the compressor. If the compressor tries to kick on while the truck is turned off it can create a heavy amp draw and blow the fuse. If you have a slight leak in the system, it will drain everything and won't allow you to air up.
01-01-2009, 06:18 PM | #10 |
Happy to be here
Just an FYI- I "always" leave my truck at ride height when sitting overnight. That way I know if I have a leak as soon as I see what height the truck is at.
01-01-2009, 06:27 PM | #11 |
WTB this ad
Hmm, I see the logic behind that but I thought it was advised to air em out when they weren't being driven. Mine loses less than 10 pounds in 24 hours, which is difficult to see without checking the gauges.
01-05-2009, 12:02 AM | #12 |
Happy to be here
Loosing a slight amount of air is common. I just don't want to find I have a steady leak after I have left the garage.
01-05-2009, 08:00 AM | #13 |
Village Idiot....
Also check your "grounds" that has been our #1 source of failures.
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
01-05-2009, 10:54 AM | #14 |
Junior Member
i am following this thread so be sure to hit me up if you need anything. You can also get me directly at my desk at 812-481-4704 or Tony@ridetech.com
01-10-2009, 12:12 AM | #15 |
Junior Member
Guys...I went to work, started the truck and everything worked fine. The lcd screed took a second to turn on then it would move up and down ok. Thanks for the help...and tony I will pm email if it happens again.
01-10-2009, 01:13 AM | #16 |
Señor Member
Let it ring a while...
01-10-2009, 02:22 PM | #17 |
Hhmmm . . .... Why isn't his other hand on top of the desk ?
