Old 01-01-2009, 03:59 PM   #1
bw4sale
bw4sale's Avatar
Make sure your connections are good!!
Some of you may have seen this, but I never have. It got hot enough to melt the lead in the connector. It was arcing where the wire met the connector. Couldn't find any reason except a bad connection, not tight enough. That's the verdict unless anyone else has any ideas.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 01-01-2009, 04:01 PM   #2
69halfton
69halfton's Avatar
Re: Make sure your connections are good!!
unbelivable! thats the first, and hopefully the last time i ever see that!
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 01-01-2009, 04:14 PM   #3
cdowns
cdowns's Avatar
its also a good practice to put the connecter all the way onto the terminal
Old 01-01-2009, 04:46 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Personally, the only time I've used those connectors is for an emergency or can't find the right length. I've never seen this problem but have had a lot of connection issues with them.
68gmsee is offline   Reply With Quote
Old 01-01-2009, 05:44 PM   #5
Painter D
Painter D's Avatar
That's the first time I've ever seen that happen.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 01-01-2009, 05:57 PM   #6
70cst
70cst's Avatar
WOW!! Holy open-short circuit!!
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-01-2009, 06:38 PM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Whoa!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-01-2009, 07:52 PM   #8
lowriden58
lowriden58's Avatar
Looks like a T-1000 is coming to live under your hood
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 01-01-2009, 07:55 PM   #9
German_AC
German_AC's Avatar
1970 Chevrolet C/30
1972 Chevy Nova SS Coupe
1977 Chevrolet C/50
1995 Chevrolet P30 - Grumman Olson Route Star
German_AC is offline   Reply With Quote
Old 01-01-2009, 08:18 PM   #10
bw4sale
bw4sale's Avatar
Yeah, I guess I was in a hurry when I connected the battery. Those style connectors were put on by the p.o.
BRENT
Old 01-01-2009, 09:02 PM   #11
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
personally i like the gm style side post
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 01-01-2009, 09:13 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It's a graphic example of what can happen to any electrical connections that aren't done properly, whether vehicles or structures. Any looseness at all will result in some degree of arcing. The more it arcs, the more it heats up. The sulphuric acid within a battery, as the battery discharges, creates a very explosive gas, hydrogen sulphide. If you've never seen an automotive battery explode, you're lucky. I hope you never do.
Member Nr. 2770
Old 01-01-2009, 10:05 PM   #13
Cunit69
Never heard of an open short cicuit, is that something new?
Cunit69 is offline   Reply With Quote
Old 01-02-2009, 12:21 AM   #14
Kayotic
Kayotic's Avatar
Fortunatly who ever tinned those cables used a low heat solder. Still atleast 600-800 degrees though. Ouch. Every one be carefull with stuff like this. I had a batt. explode on a backhoe once. Turned the key, then boom, cracked in half and loud as hell. And that batt. was never abused.
Never mind about the tinned cables, Damn, that is hot. I took a second peek at the pic.
Kayotic is offline   Reply With Quote
Old 01-02-2009, 08:49 AM   #15
bw4sale
bw4sale's Avatar
My cousin once put the battery in and connected it BACKWARDS in my granddad's 68. I had to go through and replace a lot of fried wires.
BRENT
Old 01-02-2009, 09:16 AM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Never quite seen that before... note to self, check the battery terminals when I get home.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-02-2009, 10:07 AM   #17
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
[QUOTE=Kayotic;3060724]...I had a batt. explode on a backhoe once. Turned the key, then boom, cracked in half and loud as hell. And that batt. was never abused....QUOTE]
A battery that is low on electrolyte may emit more hydrogen sulphide than full battery. Batteries that are being charged definately emit more. Fill up the battery with distilled water BEFORE you charge it. Keep any ignition source (flame/spark) away from a charging battery.
Member Nr. 2770
