Old 12-04-2002, 05:43 PM   #1
72bigblock
crossmember
hi all i just dropped my 402 and 400 in the frame and the trans crossmember don't line up with the trans. mount. it is about 1 inch off it is a 71 frame with 72 mounts help! chris
72bigblock is offline   Reply With Quote
Old 12-04-2002, 05:56 PM   #2
crazy longhorn
Fabricate till you "puke"
Do you have a short tail 400T (4"tail)?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-04-2002, 10:26 PM   #3
72bigblock
yes it is the 4'' tail it is 1'' too far back crossmember is in last holes!
