why is my positve terminal getting hot?
on my battery iv noticed that when i unplug my battery my terminal on the positive is hot, it was never like that!
anyone? |
#2 | |
Re: why is my positve terminal getting hot?
Are you sure that it is making a good connection? Bad connections make heat.
![]() Join Date: Sep 2006
Did you see the recent thread about what a poor connection did to my connector?
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
clean tight connections are the way to go all the way thru an electrical system
sounds like the connection needs to be cleaned...id take it off and either replace it or use a bottle brush with some baking soda and light water
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
Why are you disconnecting it?Are you disconnecting it because it drains (or seems too) when sitting?An over charging system will heat up.A battery will boil.You can smell the cxooking solution when it get`s bad.This is caused by voltage regulator/alternator problems.
had this problem before it came to find out when i jumped another car with my truck it messed up my battery somehow and my battery would get to hot...turned it to the place got battery from got a new one free
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Resident of Here
He unplugged it to put in a hamster and wheel.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Could be a bad connection on the ground side. Is it only hot while cranking or does it seem to be constant? As stated above, check connections starting from the batt. terminal. Hopefully you wont have to dig to deep to find the prob. I'd hate to plug in a new batt before the problem is solved.
Back in the day I had a car I was cranking to start. Took a while and wouldn't start. By the time I opened the hood to look, my pos. terminal was hot. I grabed a fist full of the neg cable to spin the connector slightly(no tools) on the post to temp. clean. She started right up, never bothered me again. |
Rottenwood Garage Member
You could also have a bad relay under the dash...one of the big ones above the fuse panel. That will cause a battery drain and the terminal and positive wires to get hot.
You can mess up that relay by using the boost part of a battery charger
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 01-02-2009 at 06:04 AM. |
A starter on it`s way out will draw hard enough on a battery to heat the hot side.On a diesel with dual batteries I`ve melted the post out of a battery cranking on it alot when it wouldn`t start.
Same on my bike.I went through two batteries with melted positive posts before going to a high torque starter.
Old Skool Club
![]() Join Date: Jun 2001
Batteries that are low on electrolyte and/or in a discharging status, will heat up and smell. 27 years of experience w/electric fork lifts.....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#13 |
Keepin it runnin!
Trace your positive cable, its not shorting out anywhere is it? If the cable isnt hot then disregard. If its just the terminal, clean/replace as stated above.
Frank
1970 K-5 4X4 Blazer ![]() 1970 K-20 4X4 Long Bed ![]() "Liberty Means Responsibility, that is why most men dread it" |
#14 | |
Old Shovel Rider
I installed a late 70's 80 amp alternator and rewired the harness for a built in regulator, so at least the end result was an upgrade. Last edited by DB Smith; 01-02-2009 at 03:02 PM. |
#15 |
your alternator connector might be backwards take a multimeter and read your charging systme idealy it would charge between 13.5 to 15.5 volts if its charging higher than that your alternator is shorted or your connectors are backwards.... also a short some where such as your fuse board would cause the vehicle to pull more amps through your positive terminal making it get extremely hot... a good example of this is in your starter... it happened to me and i didn't notice it and it ended up blowing off my positive terminal.
![]() Last edited by longhorn_SD69; 01-02-2009 at 05:02 PM. |
