Old 01-01-2009, 09:02 PM   #1
CTENTA1
Registered 1971 K5
Dana 44 Caliper plates
are they interchangeable,is their a left or a right side?
CTENTA1 is offline   Reply With Quote
Old 01-02-2009, 12:45 AM   #2
1-tonmudder
Modern day Fred Sanford
1-tonmudder's Avatar
Re: Dana 44 Caliper plates
IIRC they are interchangeable.
1-tonmudder is offline   Reply With Quote
Old 01-02-2009, 12:57 AM   #3
CTENTA1
Registered 1971 K5
im working on 71 chevy blazer fornt dana 44 axle. i got the passenger side all mounted with caliper rotor hub wheel and ready to roll. the driver side caliper plate is not letting the caliper mount. both the top and bottom of the plate rubs with the inside of wheel-rim. im thinking its going to be bent. i just wanted to make sure they were interchangeable before i started to grind or mess with.
if i go to bone yard what kind of truck and year can i look for to get a caliper plate that fits my blazer?
Old 01-02-2009, 01:08 AM   #4
1-tonmudder
Any 72-87 Chevy/GMC Dana 44/10 bolt will work as long as it's the same lug pattern and disc.
Old 01-02-2009, 01:17 AM   #5
CTENTA1
Registered 1971 K5
ok, sounds like i might be taking a trip down to the bone yard soon.
thanks for looking out bud!
Old 01-05-2009, 12:31 AM   #6
CTENTA1
Registered 1971 K5
Turns out their is more than just one design. I was able to find some brackets at the bone yard got them 2 for $20 the guy had them taken off already what a score!!!.They looked correct but when i installed it i noticed they have a little hump groove by the top and bottom caliper mounting bolt.and my originals do not. well turns out that hump deal pushes the caliper out towards the wheel, this causes the inner brake pad to not fit in between the rotor and the caliper. there is just no way. I know its beeing installed correctly because the passenger side is all done and rolling with my "in good shape original bracket".
there are some numbers behind each bracket and im thinking thats the I.D or part # ?
My correct bracket has #35692
Incorrect bracket has#35700
These #s are located next to the caliper mounting holes.(on bracket)
Im still searching for correct brackets. Any info welcome thanks guys!
