I smell gas
I've noticed that there is the strong odor of gasoline that appears to be coming from my exhaust. My cloths reek from the smell after I let it sit running for awhile. I've checked and there are no leaks anywhere. It's a 327 with TPI. What gives?
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
Re: I smell gas
i would say its running rich, I have no idea what tpi setup yu have but i would get hooked up to a puter and see what needs to be done to lean out some
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
Re: I smell gas
It's a 90-92 conversion using the MAP sensor.
Re: I smell gas
Pugs is probably right about the source, but how is it getting in? Is tank still behind the seat? Check for leaks, since it's TPI I assume you changed out the tank to the back. Your probably have a hole or two between the inside and outside. Might be fresh air vents too that are not sealing, or door seals. You can check by getting a strong trouble light and having a friend run it around the firewall, doors, and under cab in the dark while you look for light. If exhaust is dumped right under the cab or bed that does not help either. Good luck.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Re: I smell gas
Are you throwing any codes? Any pics of the engine bay for kicks? My '88 IROC and '54 are TPI. Do you have the decoder for your check engine light? I just got the Craig Moates software for my laptop and it is way more help when tuning your TPI rod.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() Last edited by Daniel U; 01-04-2009 at 02:50 AM. |
