01-01-2009, 09:41 PM | #1 |
It followed me home?
Shortened 1 ton = poor ride quality?
So I was going over my plans to shorten my crew cab 2wd with the guy doing the machine work on my motor and he said if I shortened it, that it would ride aweful and really stiff? Any truth to that? Is that why I see most shortened crew cabs changed to 1/2 ton? Anybody have experience here? thanks
Adam
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-01-2009, 10:17 PM | #2 |
67-72 parts collector,…
Re: Shortened 1 ton = poor ride quality?
NO WAY!
It won't ride any worse than a standard cab longbed. If a shorter wheelbase was terrible,... blazers would be horrible. I say cut it down.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-01-2009 at 10:18 PM. |
01-01-2009, 10:22 PM | #3 |
Thats kind of what I was thinking, I really want to keep this thing 8 lug. So why does everyone shorten their 3/4 or 1 ton crew cabs and make them 1/2 ton?
01-01-2009, 10:41 PM | #4 |
I guess because Gm didn't make one. That's what I will eventually do to my 1-ton cew cab.
Hill's Hot Rods left theirs a 3/4-ton (or 1-ton?) for hauling purposes.
01-01-2009, 11:23 PM | #5 |
01-01-2009, 11:30 PM | #6 |
Luv the Crewcabs
Send a pm to ojoe & Ask about his Ride Quality, He has Built a Couple of them. I went with 1/2 Ton on the Crew Im working on because i had the Drop & Tire/rim Combo allready.............
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
01-01-2009, 11:33 PM | #7 |
its just $$$$$
I think mine actually rides a little better now than before
01-02-2009, 12:30 PM | #8 |
It'd be alot cooler if you did
OK, in general a longer wheel base rides better because there is a longer distance in between the wheels, which means the suspension has more recovery time.
01-03-2009, 01:39 PM | #9 |
its just $$$$$
even if it rides a little worse...the improved turning radius is worth the trade off...lol
01-03-2009, 01:42 PM | #10 |
shorter wheel base vehicals will have reduced ride quality, but it's all depending on shocks, springs, mounts, etc....as to haw much worse it will be. You will feel the bumps more, because the suspension doesn't have to time to recover between the to axles....
Duro
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
01-03-2009, 11:10 PM | #11 | |
Señor Member
I also believe most people won't notice/care in the ride difference, especially when they pop on their rubber band tires and feel the ride quality of those things.
