01-01-2009, 11:15 PM | #1 |
Camaro tach dash questions W/Pics
I recently bought a camaro tach dash project from a board member. I cannot figure out the wiring? HELP
01-01-2009, 11:21 PM | #2 |
Re: Camaro tach dash questions W/Pics
ttt
01-02-2009, 03:13 PM | #3 |
C10 Club Tennessee
ttt
Can anybody help Jeremy out? I'm the board member who sold it to Jeremy, and I don't remember which one is which. Any help would be appreciated. I don't want Jeremy to have to wait too long to install his tach.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 01-02-2009 at 03:13 PM. |
01-02-2009, 03:26 PM | #4 |
Why is that apart? Where is the mounting plate? Here are 2 threads on this.
http://67-72chevytrucks.com/vboard/s...d.php?t=137155 http://www.67-72chevytrucks.com/vboa...d.php?t=251017
1997 GMC Sierra Ext 1965 Mustang |
01-02-2009, 03:35 PM | #5 |
member #16
There are two camaro tach writeups in the FAQ section. FAQ link in my sig.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-02-2009, 04:59 PM | #6 |
Ive looked at the above links and it still does not tell me anything.
The "module" i have has three bolts that do something. Is one them a power and the others coil and ground? How would i tell them apart with an ohm meeter? Any help would be greatly appreciated. The two wires comming from the tach in the above pics are black and white and are directly connected to the circut board. none of the three bolts connected to the circut board are next to or look to be an obvious black or white wire. HELP! Last edited by jwn1975; 01-02-2009 at 05:00 PM. Reason: spelling |
01-02-2009, 05:08 PM | #7 |
If it helps, The two bolts in the second from bottom pic, only go through a small ammount of the circut board. The third bolt looks to use the most of the circut board?
01-03-2009, 03:26 PM | #8 |
Truck and auto performance nut
What year tach is that? Looks different from mine.
Mine has 2 connections on a rear mounting plate(4"x4"?) that has the main circuit board (2"x3"?) and tach/housing mounted to it. Yours looks like it has been modified or for a different year? One connection is 12v the other is for the coil...and a ground.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
01-03-2009, 04:02 PM | #9 |
Thanks for the tips. I'm going to give this a try.
69 Chev SWB (project) 70 Coupe de Ville (been in family since new 52k orig) 05 Corvette conv (custom everything) 56 Chev SWB big window(been in family since 59 project) |
01-03-2009, 04:03 PM | #10 |
I think that he is looking for some advice on how to test it with the continuity tester. Any advice?
I am no expert on them.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
01-04-2009, 01:12 PM | #11 |
the back of the tach says 1976
01-04-2009, 01:45 PM | #12 |
Again, it looks like you are missing the main circuit board, the insulator board & the mounting plate. In fact, what you are showing, doesn't even look like what is shown in any of the FAQs. Mine is different than that also. Do you have a picture of the front of that tach?
At any rate, look at the way I wired mine. On the back of the tach from left to right, is black wire to the coil(or tach) on the HEI distributor cap, Red wire to a 12 volt source & the green wire to chassis ground.
01-04-2009, 08:21 PM | #13 | |
Hey 70GMCer,
Let's see the front of that there instrument cluster. Quote:
