Old 01-02-2009, 12:19 AM   #1
sstpeach
View Picture: was it changed over to V8 from 6 cylinder?
66 truck purchased without engine. The truck was built with a six cylinder from the factory. How do I know its still configured for a six or changed over to a V8? Can someone tell me from my photo? I can take additional photos as required.
thank you,
steve
sstpeach is offline   Reply With Quote
Old 01-02-2009, 12:24 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: View Picture: was it changed over to V8 from 6 cylinder?
The motor mounts are for a V8. The 6's had extenstions to reach the perches. If you are going to put a automatic in that truck you will be losing the rear crossemeber in the picture. Those mounts are not needed but you will have to get a automatic crossmember for the tranny.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-02-2009, 11:09 AM   #3
sstpeach
Ok, got it. One final question........after I remove my crossmember I will have to install a new one as I plan on using a 350 automatic transmission. Will the crossmember from the donor transmission vehicle work or do I have to find a 60-66 chevy specific crossmember?
steve
Old 01-02-2009, 01:29 PM   #4
steverino66
steve
You can use one that fits under the tail of the trans from a 67-72 truck - you may have to drill holes to bolt it to the frame rails (there are some original 66 versions out there, but more pricey)
steverino66 is offline   Reply With Quote
Old 01-02-2009, 05:54 PM   #5
Chevy Fleetside
Mine came out of a 67 automatic truck. I believe you can use them out of the 73 and up also, but will have to probably redrill. GM didn't change to many things over the years.
