Old 01-02-2009, 12:32 AM   #1
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
Exclamation 65 window re install
ok so i had to take my windows out a while back with all the mechanisms and everything and now me and pops are ready to put them back in,we have never done it before and know how much of a pain it was to take em out,
so basically what im getting at is do you guys have any pictured installs or word of advice/wisdom
it would be more than appreciated
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 01-02-2009, 02:36 AM   #2
Hickup pickup
Hickup pickup's Avatar
Re: 65 window re install
Hardwaa and I just did this to his truck. I have installed many windshields in various cars and trucks and this was one of the most difficult installs i've done , so my advice is find someone who has some experience even if it means letting a few moths outa the wallet!Good luck.
2-20, 2-21 whatever it takes!
Hickup pickup is offline   Reply With Quote
Old 01-02-2009, 01:55 PM   #3
salazar44
65 - Chevy C10
salazar44's Avatar
Good cord string and lots of wd-40! After seeing the guys install mine i was pissed i spent the money for it. I think I could have done it.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 01-02-2009, 02:23 PM   #4
Hillbilly Deluxe 65
sorry i meant side windows along with teh vent window i already have installed teh windshield and back glass
1BADD65
my build thread:
Old 01-02-2009, 11:26 PM   #5
2manyprojects
2manyprojects's Avatar
If you put things together in the right order, it's not too bad. I usually put the vent and the regulator in first then the glass. get that started in the track then line everything up and bolt it down. The trick is leave it all loose until the end. If you cant get it, I'll be down your way in the next week or 2 I can swing by and give you a hand if you need it. Feel free to hit me up if you have questions.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
Old 01-03-2009, 12:21 AM   #6
Hillbilly Deluxe 65
i appreciate it man we got one thru trial and error and the next one will be a breeze only problem we are having witht eh drivers do is that the door wont shut right with the new rubber, before the new rubber it you still had to slam it but now that its an issue im thinkin it might be the door latch that has just been worn out and the gear inside wont quite click on the last tooth it needs to
sorry to ramble, but any thoughts?
1BADD65
my build thread:
Old 01-03-2009, 12:35 AM   #7
2manyprojects
It could be a worn out latch, but check the striker (piece on the body) and see if that's adjustable. I cant remember. Watch it as you close the door and see if it's lining up. Usually having to slam the door is worn out hinges. pick up and down on the door and see if you have play. If all that is ok you might just have to wait until the rubber gets broken in and it will probably get easier. Also the door guts add weight, and might make it sag some where you need to readjust it.
