1970 Daily Driver
Master Battery Disconnect Switch Placement
I am going to install a Cole Hersee Master Battery Disconnect Switch 2484-A, in my 70 Chev. I was wondering if any one had advice as to placement of the shut off switch or pictures of where they put it so that it is convinent and out of site.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
![]() Join Date: Oct 2005
Re: Master Battery Disconnect Switch Placement
Here's where I placed mine. The hole with indentation was already there and it's right under the battery and easy to wire. I also turned my battery (side terminal) around so the terminals face the rad support....just made it look cleaner. I was a little concerned how hard it would be to reach when the grill was on, but it's no problem at all.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Wow I did mine the same exact way... I also turned the side post battery forward and ran my wires down thru the frame...Can't see my switch on this pict thou.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#5 | |
MOVE OVER
No matter where you are..... There you are... Buckaroo Banzi |
1970 Daily Driver
That looks like a great place to put it. Looks like I will need to buy a short 2' battery cable to go from the battery to the switch, then i can just hook my existing cable to the other side of the switch and I will be done. Thanks a bunch. Check your User CP at the top of the page I will leave you some rep. points.
![]() Join Date: May 2006
Been wondering the placement as well,thanks for the ideas, also turning the battery around to clean up the cables
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
its all about the +6 inches
hmmmm..I never in a million years woulda thought of turning the battery around.
1970 Daily Driver
If you had to give some one a jump or be jumped is it possible with the cables turned around? I guess if you left some slack in the battery cables you could pull the battery out enough to get the cables on. I think I might do the same. I just bought a battery that has both top and side posts but that would defeat the clean look. I will take it back tomorrow and exchange it for side only, good thing they forgot to punch out the date.
maybe im just slow, but whats the point of the battery cut off.
i mean, they make us have them on the race cars, but thats so that the saftey guys can shut them off when you flip the thing over and there is gas all over the place. whats to point of having one where you cant get to it really fast? not trying to be mean, but just asking?
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
1970 Daily Driver
When my truck was a daily driver through the winter (was till this winter) I had no problems. When I decided to get a winter car this year and parked my truck I didn't think about unhooking my battery and now because of a draw some where my battery is gonzo. I decided to put the cut off on the truck so that I can just flip the battery off when I decide to park it for awhile. That way if there is a nice day i can just reach under and flip things on and be on my way.
I have a fiberglass rear roll pan and have the switch mounted there, as the battery is mounted in a rear box behind the right rear tire also. I did it that way 9 years ago and never got any grief from the NHRA track inspectors.
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB Gasser 364"LS and all the goodies 2001 Vette Road/Street 1990 IROCZ Vert |
#13 | |
I also agree with the "whats the point on a street car" comment. |
#14 | |
Moderator
![]() Join Date: May 2007
#15 |
I think the battery disconnect is a great theft deterrent but I have one question. Wouldn't you lose all your radio station and bass, treble etc. presets including the clock on the newer stereos we put in our trucks?
#16 |
that feature is very easy to preserve. All it takes it a small wire on the battery side of the switch going to the radio.
#17 | |
I agree, but rollover is a possibility in the future of mine
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-03-2009 at 03:10 PM. |
#18 |
theft deterrent is one reason I added it, also I dont drive my truck sometimes for weeks at a time.
Originally I have a top terminal battery as you can see in the pict and the wires are ran straight down now I have a side post and you definetly dont see anything.
#19 | |
Some of the more expensive switches have "by-pass" terminals for radios, clocks, etc, built right into the housings. Some are also made to have the movable part of the switch removable like a key. This would make for a litttle more security if that is the goal.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#20 | |
I also popped off the E clip so I can remove the knob/shaft assembly
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-04-2009 at 11:21 AM. |
#21 |
![]() Join Date: Feb 2001
Thanks all...this is great info! That tip right there is worth the membership fee to me.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-05-2009 at 09:11 AM. |
#22 |
1970 Daily Driver
Got my switch installed last night. I had to drill a whole 2" to the left of where you guys put yours. That hole and indention you used is where my blinker wiring and grommet come through. All I had to do was run my original positive lead to one side of the switch and then I bought a 2' cable to go from the other side of the switch to the battery. I also ran a dedicated wire from that side to my radio to keep my settings.
I noticed that you can remove the turn lever on the switch as well that will help with keeping it more secure when I am out of town. Some would think it was a bit over kill but I say for around $30 it is money well spent. Helps save you battery if the truck has to sit for awhile and might even stop some ones hasty attempt to steal the truck. Or if you are working on your engine and need it shut off real quick all you have to do is reach down and switch her off.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 01-06-2009 at 11:41 AM. |
#23 |
Two additional great ideas! Nice!
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
#24 | |
Active Member
![]() Join Date: Jul 2007
#25 |
Eat My Rust
So you guys are putting this on the positive side of the battery? When I thought about it, I was looking at the ground cable, but maybe that's because I run things off a fuse block already on the battery..
And what ones have the extra power lead? Last edited by texanidiot25; 01-10-2009 at 10:34 PM. |
