Old 01-02-2009, 02:35 PM   #1
sleepertruck72
sleepertruck72's Avatar
Question Parking brake question
I have removed all the pieces from the parking brake cable on the 72 C10 parts truck I have. The only part I cant figure out is the rod or guide whatever its called on the passenger side of the frame. Is there a trick to get it out, or does it not come out ?
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 01-02-2009, 02:52 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Parking brake question
I would have to go look at the parts trucks. but IIRC i thought i saw a T-bar type connector bolted to the rod that the cable ran through . if you remove the nut, can you remove the rod by pushing it back through the frame towards the front.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-02-2009, 03:36 PM   #3
sleepertruck72
Here is what the ends look like. They dont seem to be removable because theyre flared and wont fit through the hole in the frame. I eventually will swap my parking brake handle on my 67 to the foot pedal so I wanted to keep everything from the 72 to make it easier.
72 C20 Longbed
05 1500 Z71
Old 01-02-2009, 05:38 PM   #4
Aarons72s
The end with the washer should be on the outside of the frame. And you should be able to just pull it out from the outside of the frame. That is the way they were put in at the factory and most usually just come right out. If It doesn't want to then either the hole got messed up or the flared end that is on the inside got messed up. If all else fails just cut off one of the flared ends. I have seen people do that and just thread the end and put a nut on it like the way the cable ataches to the links on the drivers side. I hope this helps.
Aarons72s is offline   Reply With Quote
Old 01-02-2009, 07:26 PM   #5
sleepertruck72
I will try that. Of all the days I get some free time and it started to rain right after I'm out there.
72 C20 Longbed
05 1500 Z71
Old 01-03-2009, 01:48 AM   #6
Aarons72s
Sounds like my luck.
