![]() Join Date: Jan 2009
2wd to 4wd
have any of you guys ever converted a 2wd 1971 c10 to a 4wd
just wondering how much work it involves |
Re: 2wd to 4wd
This should be moved to the 4x4 forum... I've done or am in the process of doing a full frame body swap...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
Post Whore
![]() Join Date: Feb 2000
Re: 2wd to 4wd
Yep, head over to the 4x4 subforum - there is almost always an active post asking about this.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Re: 2wd to 4wd
take what you got now and find a 4x4 frame that it will fit on but i would talk to the 4x4 frame. something else you need to look at is your low hump in the cab you might need to find a high hump floor for it
