Old 01-02-2009, 07:40 PM   #1
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
79 Big 10 lowering
ok, this past week, I have been messing around with ride hieght on my 79. It is a Big 10. I removed some leafs in the rear, and put on 2" drop coils. The rear is way to loosy goosy right now, planning to add back in the thicker leaf and remove another.
My question falls with the front end. Is the Big 10 not a "3/4 ton" coil spring? Sitting 1.5 - 2" higher than a non heavy half? So putting the 2" drop coils on, it only dropped 1.5-2"..... Whats the deal with that?
If my truck sits 1.5-2" higher in the front than a non heavy half, wouldn't a 2" drop coil put me down at least 2.5-3"?
The first picture is a before, and the second is current.
Is it possible that a Big 10 has a spindle that sat the truck up a little higher? What are your thoughts?
bowtieguy79 is offline   Reply With Quote
Old 01-02-2009, 07:56 PM   #2
71Farmtruck
Junk Junkie
71Farmtruck's Avatar
Re: 79 Big 10 lowering
I dont know about the rating of the spring, but according to your logic you are correct. I wonder if spindle heights might be different.
Mike
71 Chevrolet C-10 Short Bed Stepside
81 GMC 1500 Sierra Classic Long Bed
71Farmtruck is offline   Reply With Quote
Old 01-02-2009, 09:00 PM   #3
boatpuller
boatpuller's Avatar
i'm likeing the way it sit's.it's got a nice stance.tire's look good in the wheel well.as far as your spindle ?....you might want drop spindle's.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 01-02-2009, 09:04 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Springs do get old and sag after awhile. Also could have been swapped out for light duty springs by a previous owner ?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-02-2009, 09:33 PM   #5
f.monroe
f.monroe's Avatar
I have had original trucks with the heavy duty suspension and they never sat as high as my 77 long bed did when I installed new springs . They may have sat higher 30 years ago but have settled over the years . Your new springs will settle a little . Also , what is the weight of the new engine vs the old all iron engine . That might account for and extra 1/2 inch in height due to the weight diff if there is any .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 01-02-2009, 10:58 PM   #6
bowtieguy79
Ephesians 2:8
Ya they do, I don't think they had been changed. I have had it for 11 years, and it was EXTREAMLY stock when I got it.
Frank
Compared to my brothers 77, I was 2" higher than him all around, but yes, I suppose they could have sagged over the years. Good point on the LSx being lighter than the Iron 5.7L. It did sit up a little higher with the LSx installed.
Old 01-02-2009, 11:56 PM   #7
heavychevy79
Cheyenne Super
heavychevy79's Avatar
I still have my old big-10 spindles somewere, I dig them out and mesure them
and mesure the reg C-10 spindles I have now.
I to noticed that those 2" drop springs didn't seem to drop it much.
I got rid of the DJM 3" drop spindles I had on my 77, with the 2" coils they were just too low, I was draging the ground and tearing up my lawn.
I'm going to try some that are 2" or 2.5" drop, but I'm not sure what brand to go with.
I didn't like grinding those DJMs to make my 15s fit.
heavychevy79 is offline   Reply With Quote
Old 01-03-2009, 12:06 AM   #8
bowtieguy79
Ephesians 2:8
That would be cool, if you could measure to see if there is a difference. I'm thinking of getting the 2.5" Summit drop spindles some time in the future.
Ya Id hate to grind on expensive parts...
Old 01-03-2009, 10:05 AM   #9
grinch4om
dang its hot
grinch4om's Avatar
the stance is good in my humble opinion. It will sag with time. to tighten up the rear, put a sway bar on it, that will take the loose feeling out
grinch4om is offline   Reply With Quote
Old 01-03-2009, 10:10 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The only reason GM built the "Heavy Half" trucks was for emissions reasons. During that time, all trucks 1/2 and smaller had to comply with stricter emissions standards, so GM built the trucks and rated them 5/8 ton or "Heavy Half".
Old 01-03-2009, 10:52 AM   #11
grinch4om
dang its hot
grinch4om's Avatar
I did not know that!
Old 01-03-2009, 09:47 PM   #12
71Farmtruck
Junk Junkie
I always liked the Western brand spindles, they're cheap and they work with 15" wheels fine. The only thing I had to do on mine were to tap the dust cover holes, for some reason they came only drilled.
I ate a spindle the other day when a wheel bearing came apart, I am swapping in spindles and brakes from a '79 Suburban I had laying around on the '81, I will compare those spindles for differences. The brakes are definitely bigger.
Mike
Old 01-03-2009, 10:51 PM   #13
bowtieguy79
Ephesians 2:8
can't wait to hear if you guys see a difference.
Old 01-04-2009, 01:46 AM   #14
heavychevy79
Cheyenne Super
I didn't get a chance to dig them out today, everyone had their car over
here for me to work on.
I wonder if the 1 1/4" rotor spindles are a different hight than 1" rotor spindles?
I didn't know that about the 5/8 ton emissions rating, thanks for that.
How much are those Western spindles, and how much drop?
I'll check out those Summit ones also. I'm going to some feedback from people
before I spend my money this time.
Old 01-04-2009, 05:06 PM   #15
71Farmtruck
Junk Junkie
I think it was $200 for the pair, and 2.5" inches of drop.
Mike
Old 01-05-2009, 01:30 AM   #16
heavychevy79
Cheyenne Super
Thanks.
I found their website, but there are no part numbers to put on the order sheet, I would have to fill out All of my info and discription of the part I want.
And nowhere does it say how much shipping is.
But shipping is free til Jan 7th I think, so they would only be $229
I do like those spindles.
GodfatherCustoms has McGaughy's 2.5" drop spindles for $227 or $257 with
shipping.
I have it down to those two brands.
I don't trust that cheap brand Summit sells or the Summit brand either, does
not say where either are made, or who made them.
Sorry I was really busy today and did not get to dig for those big ten spindles yet.
If they were not in my neighbors yard in a deep pile of junk I would dig for thim right now.
I don't want wake him up with the sound of a scrap metal avalanche. lol
Old 01-05-2009, 09:27 AM   #17
Tx Firefighter
Summit sells Belltech, which is the finest stuff made and their Summit brand spindles I bought were Ground Force, also good stuff.
Old 01-05-2009, 03:41 PM   #18
bowtieguy79
Ephesians 2:8
Summit is good about choosing good suppliers. There K&N "look a like" filters actually are K&N filters. Mine came in a plane box, with K&N plastic over the filter.
Old 01-05-2009, 04:32 PM   #19
Ds86C10
2WD 4 Life
Ds86C10's Avatar
Thanks.
shipping.
all the summit brand parts ive bought are name brand parts in plain boxes...
Big D
1969 c10
1960 cadillac
1978 king cobra
Ds86C10 is offline   Reply With Quote
Old 01-05-2009, 09:17 PM   #20
71Farmtruck
Junk Junkie
Sport Truck Direct sells Western
Mike
Old 01-06-2009, 03:38 AM   #21
heavychevy79
Cheyenne Super
Yeah that was the site I was on, it looked like it is part of of Western company, but I'm prob wrong.
I guess I should get those while they have free shipping.
I'll get those spindles out today. Oh and the springs might be there too, so
I'll mesure them also if I find 'em.
Old 01-06-2009, 03:37 PM   #22
71Farmtruck
Junk Junkie
Get yourself some drop hangars and shackles as well, they are hell to install but are way better than messing with your leaf springs
Mike
Old 01-07-2009, 03:10 AM   #23
heavychevy79
Cheyenne Super
Huh, oh yeah I was talking about mesuring the front coil springs that were on my truck, but I did move the hangers, and did shackles, and removed two
springs, which was very hard compaired to doing a flip kit IMO.
I kick myself now for not doing a flip kit and saving myself the trouble of
grinding off all the rivet heads, and then drilling the rivets, then prying the
hangers off of the rivets/frame, then centering on the marks and welding.
Installing the shackles was not that bad, but removing those two leafs from
the spring pack was a workout.
Maybe the only drawback from a flip kit is you will have to grind off the
bump-stop bracket, four rivets I think.
But anyway there must be something that makes a Big 10 higher than a normal 1/2 ton. Could only be springs or spindles.
I asked my neighbor to dig those spindles out, but I think he was too tired.
He works night shift a Target and I think over 40 hours this week allready.
I gave those old parts to him to scrap, but he put them up someplace insted.
He's a Chevy head himself.
Old 01-08-2009, 05:00 PM   #24
heavychevy79
Cheyenne Super
We could not find those spindles or springs, but we can still figure it out.
I mesured the spindles from the 79 I had that are on my truck (was a reg 1/2 ton) and the spindles on a 73 I just got, I mesured from the very bottom of
the spindle to the center divot (backside) of the spindle shaft, and got 2-5/8"
The 73 looked to be closer to 2-3/4" but it is very greasy.
So all you have to do now is mesure yours, then we'll know for sure if they
are different.
Old 01-27-2009, 02:27 AM   #25
heavychevy79
Cheyenne Super
Bump... Please don't let this thread die.
