"the other guy"
250 throttle linkage
i need pics of the throttle linkage for my 67. how are you sixers hooking them up to your throttle cable? thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 250 throttle linkage
I don't follow you, a 67 truck had a throttle rod, not a cable.
"the other guy"
i realize that, it must have been swapped out at some time.
Sorry, if my reply came off as smart alleck. I didn't intend it that way at all.
If that's the case, you can use the later throttle brackets. When I converted a 68 model 6 cylinder engine over to a 72 truck, I found the little pivot bracket for the manifold off of a later engine (a 250 in an Impala car) in the junkyard. With the factory bracket, it only took a minute or two to get it hooked up and working smoothly. There is a little pin type of bolt that screws into the manifold and a bellcrank that fits onto the pin, held on by a clip. This converts the cable's linear motion to a rod going to the carb.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 01-03-2009 at 10:21 AM. |
"the other guy"
Tx, no offence taken. i belive there is a 75ish pick-up in a local yard with a 250. ill check it out. thanks
