Would this work...please help!!!
Would a 68 327 out of a C50 tractor truck,it is the original motor.could it work without having to change out any internal motor parts and would a 350 or 400 th hook up to it.Motor mounts and small stuff I think I can handle,just don't want to get it,if it's gonna be to much trouble ....Need answers please,because I think this might be my diamond in the ruff....
If it ain't a chevy,I don't want it |
Re: Would this work...please help!!!
Work for what?
Yes a th350 and 400 will bolt up.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
Watch out for your cornhole !
![]() Join Date: Jun 2003
It's a just a small block Chevy. Underneath that big truck, it's the same thing you're used to. It will go directly into a smaller truck, hook up to the trans, etc...
That's what I have always liked about the older Chevy engines. They interchange in just about anything.
1997 GMC Sierra Ext 1965 Mustang |
![]() Join Date: Feb 2004
I thought that Chevy also made a larger heavier 327 industrial motor?
Is this true or not?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#6 | |
member #16
![]() Join Date: Dec 1999
http://67-72chevytrucks.com/vboard/s...ad.php?t=12457
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 01-03-2009 at 05:44 PM. Reason: add |
on some of the heavy trucks the heads were different. they had larger accessory bolt hole and they were in slightly different places. it is an easy modification just drill the bracket holes to a larger size and you need cut and make one bracket longer. Otherwise it will bolt right in but you should change the timing chain and use a four barrel intake manifold.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin ![]() 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) Last edited by bhoeger70; 01-03-2009 at 08:21 PM. |
