01-03-2009, 01:07 PM | #1 |
front axle swap
i have a 67' k10 and i am looking to put a front axle out of a mid to late 70's chev pikup with disk brakes and was wondering if the front axels where the same length thanks
67' chevy k10 350 sm420 |
01-03-2009, 03:40 PM | #2 |
Post Whore
Re: front axle swap
Yes.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-03-2009, 06:56 PM | #3 |
Re: front axle swap
are the perches the same also
01-03-2009, 07:21 PM | #4 |
Post Whore
Re: front axle swap
Yep. Only thing you might need to address is the brake lines - the ends are sometimes different. You can use adapters to mate the newer axle's rubber lines to your hard line or make a new set of hard lines like I did.
I see you have a 67 - that has the closed knuckle axle so you'll want the newer axle's steering arm since your steering arm is different.
01-03-2009, 07:25 PM | #5 |
Re: front axle swap
thanks alot yukon and nice truck
67' chevy k10 350 sm420 Last edited by 67chevtruck; 01-03-2009 at 07:26 PM. |
01-04-2009, 10:34 AM | #6 |
Post Whore
Re: front axle swap
Are you getting the axle from a donor truck? If so and if it has power steering, I'd go ahead and grab those related parts if you are thinking of adding power steering at some point. Thanks for the compliments on my truck - it is currently transfer case-less - grrr.
01-05-2009, 08:18 PM | #7 |
Re: front axle swap
im getting it out of a 76' sububan for 100 bucks and i already put power stearing on my truck but thanks for the thought
01-05-2009, 10:45 PM | #8 |
Re: front axle swap
i put one in my 68 from an 82...
check the gearing get the u-bolt plates too steering arm drag link from steering arm to PS I am doing a sway bar as well since it hook up to the u-bolt plates...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 01-05-2009 at 10:45 PM. |
01-05-2009, 11:29 PM | #9 |
Re: front axle swap
i plan on it im buying the complete suburban for 100 bucks
01-06-2009, 12:29 AM | #10 |
Windy Corner of a Dirty Street
Re: front axle swap
Don’t forget to change the brake proportioning valve and master cylinder when you convert to front disk brakes.
$100 is a good score for a 4x4 Suburban. Regardless of condition it is worth more than that in scrap weight.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
