horn wiring
I have a 1969 GMC 1/2 ton base model no power anyhting and 6 cyl 3 on the tree I got the truck part done but I have a horn in the box of parts but I cant seem to find where I goes what colour is the wire for it and where is it located I cant seem to find anything in my Hayes manual any help or pictures would be great thanks
Old Skool Club
![]() Join Date: Jun 2001
Re: horn wiring
Horn wire is green, as I remember. There should be a relay that you will hear emit a clicking sound, with no horn connected. If you hear that sound, then you should be able to have an operable horn when it is connected....unless there is a break in the wire between the relay and its terminus.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Old Shovel Rider
Re: horn wiring
You mean where the horn mounts?? On the core support to the outboard side of the radiator. It's on the drivers' side near the regulator. You should see that green wire with a coupler on it coming from the harmess near the horn location.
Re: horn wiring
take sandpaper and clean to shiney metal where the horn mounts to the core support because thats how the horn is grounded// doesnt hurt to shoot a bit of wd40 into the horn opening to lubricate the diaphram either
