Never Ending Projects
Pinion Angle Question
Hi guys, I did a search and really did not find the answer I was looking for.
I am swapping in a '74 rear end into my '68. I have cut all the old brackets off the '74 axle and have ECE axle pads to weld on. I got the axle mounted to the trailing arms and the u-bolts snugged up. I got the housing centered from side to side. I had read you wanted 3-4* on the pinion angle. and got that set. Before I welded these, I decided to check my old '68 housing. This is where I now am not sure. With the axle pads set at 0* (level) the pinion angle is pointed 12* Up. I also check with the pinion set at 0*, the axle pads point down 12* so I think my measurements are right (digtial leveler). Should I setup the '74 housing to match the '68 measurements? This in theory should keep things stock. Currently I have the axle pad set at 0* and the pinion is up 4*, which now doesn't seem right based on my '68 housing. I don't have the axle at ride height since I don't have the springs or panhard bar installed. I am putting 5" dropped springs but have no idea what ride height will end up since the bed is not on either. Any ideas??? Thank.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Hollister Road Co.
Re: Pinion Angle Question
It depends on if you have lower it or raised it. look at the link below, its the best info on prop angles
http://www.vibratesoftware.com/html_...aft_Angles.htm |
Thanks for the info. That's a good site. I actually know how to set a pinion angle but only with the suspension all setup and the car/truck sitting at ride height.
That's my problem, I don't have the suspension installed other then the trailing arms. I went ahead and set the angle and welded the pads on based on my '68 housing. I was able to cycle the axle up and down, connected to the arms and at what "should" be ride height, it looked like the pinion was bout 4* and hitting the bump stops, about 1.4*. It looks like it did with the stock '68 housing so I think I am good but won't know for sure until it's back on the road.
