01-03-2009, 09:17 PM | #1 |
ignition help
this might sound stupid, but i'm wondering what is the bare minimum i need to get my truck started? i bought a new battery. and the alternator tested good. i thing its the wiring between the key and somewhere? what is the fastest or easiest way to rewire temporarily to get it started? thanks for any help. i had it for sale but it just quit starting. the wiring looks like spagetti espically under the dash.
01-03-2009, 10:01 PM | #2 |
Re: ignition help
Do you have electronic distributor?If so:
Dis-connect the battery first! 1-Put a wire(#14 guage or larger)on the inside terminal(closest to the engine) of the starter solenoid,I'd use a spring clip for this. 2-Run a wire(#10 guage)from positive on battery to the "BAT" terminal on the distributor cap.This puts power on the coil/dist.Dis-connect any wire that's already there for now. Connect the battery again. Put the wire in 2 on the positive terminal so you can pull it off easily to kill engine. Just touch the wire 1 on the positive terminal.This puts 12 volts on the starter to start the engine.Once engine runs,remove this wire from battery. On points type distributor,do the same as above except connect the 2 wire to the + side of the coil.Do not run the engine for more than a couple minutes or you will burn the points.It needs a resistor in the circuit for longer running times. Btw,I was born in Ozark at Dale County Hospital a long time ago! Mike. |
01-03-2009, 10:10 PM | #3 |
Hey Y'all!!
Re: ignition help
So you are selling the truck? Sorry to hear it...
01-04-2009, 09:21 AM | #4 |
Re: ignition help
well i'm considering selling. if i could move the engine and tranny to my other 64 i would'nt sell. btw i work at dale medical center. ya'll have any ideas how to swap the engine and tranny without a hoist? i dont have a garage, so i have to do this all outside. thanks for the wiring help. i'll give it a try.
