Old 01-03-2009, 10:12 PM   #1
Real_McCoy
Real_McCoy's Avatar
Window regulator jammed
My driver's door window regulator jammed in the down position today. I cannot see any binding in the brackets. I believe the issue is in the handle/gear box. Will I need to replace the entire mechanism or just the gear/crank box? Any suggestions would be greatly appreciated!
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
Old 01-03-2009, 10:39 PM   #2
Real_McCoy
Real_McCoy's Avatar
Re: Window regulator jammed
OK. So I found the replacement regulator as one complete assembly from several suppliers. Does anyone have any recommendations in completing the transplant?
Daniel
66 Chevy C10 LWB
Support our troops!
Old 01-04-2009, 12:10 AM   #3
joe231
joe231's Avatar
have you tried some penetrant and some lube on the teeth?
CHEVY ONLY
Old 09-10-2009, 08:26 PM   #4
ol Curt
Junior Member
ol Curt's Avatar
CHEVY ONLY
I have found both to leave a foul taste and on occasion stain the teeth.
Sorry, couldn't resist...doing search on how to replace my regulators!
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 09-10-2009, 09:23 PM   #5
Martin64
Martin64's Avatar
I gotta put it between bologna and cheese to mask the taste.....put that on rye and it pretty much blends right in.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 09-10-2009, 10:04 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
It could be the gearbox is so dry it won't funtion, in which case one of the toothpaste options may help (LOL), however it's more likely the gearbox is broken, or it could be something in one of the tracks has come loose or broken. I've seen this happen rarely, where a piece of the lower track breaks off and hangs up the lower glass channel.
I don't believe you can buy just the gearbox, it comes as an assembly, either used or new replacement. I don't have a 65 manual, but per the 1960 shop manual which is probably very close - there are 3 steps to replace the regulator.
1. Remove door ventilator assembly, door window glass and door lock remote control mechanism from door as previously directed.
2. Remove 4 screws which attach window regulator mechanism to door inner panel; then disengage regulator idler arm from arm guide channel and remove regulator through opening in door panel.
3. Install regulator assembly through opening in door inner panel and engage regulator idler arm into arm guide channel mounted to inside of door inner panel. Attach regulator assembly to door panel firmly with four screws.
If you need more of the details about how to pull all the other stuff listed, send me a pm and I'll send you scans of the pages.
