01-03-2009, 11:32 PM | #1 |
"THE GREEN GOBLIN"
TH400 Side plug Question. What is it for?
Ok guys I have this electrical conection on my TH400 I dont remember if anything was hooked up to it or not when I pulled the transmission & motor out. If it was I have no idea where the wire that unpluged from here went or goes, Can any one help me What goes plugged in here Is it a plug for a Transmission Oil Temperature Gauge? If so I'd like to put a Temperature Gauge in my Gauge Cluster. Anyone know the size of a gauge that would fit next to the Stock Oil Pressure Gauge the small hole Thanks Pablo.
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
01-03-2009, 11:47 PM | #2 |
Re: TH400 Side plug Question. What is it for?
kick down switch
01-03-2009, 11:49 PM | #3 |
I think it's for the kick-down switch.
I'd have to look at one of mine to be sure! Mike. |
01-03-2009, 11:58 PM | #4 |
Formerly- 1972SuperCheyenne
Almost positive it's for an electronic kick down.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-04-2009, 12:02 AM | #5 |
THE DAMN YANKEE
it's a neutral safety switch. the kickdown is on the otherside of the trans.it's either a vacume hose to the intake or a detent cable hooked to the carb and it's on the right side of the trans.
01-04-2009, 12:08 AM | #6 |
thought neutral safety was on the column
01-04-2009, 12:26 AM | #7 |
its all about the +6 inches
the safety switch is on the column.
If that plug has a single spade on it, then it is the electric kickdown. If it is a double, then it is the kickdown, and the transmission controlled spark (TCS) which was an early smog control device that kept the timing from being advanced untill the engine was up to temp, and in final drive ratio. |
01-04-2009, 05:02 PM | #8 | |
"THE GREEN GOBLIN"
Petey-pablo
01-04-2009, 05:07 PM | #9 |
Coming froma guy with no kickdown... it's a nice feature to have.
However, you can leave it unhooked with no major side effects. If you floor it and it should kick down, and is unable, the line pressure can get a little high, and it can shorten the life of the tranny, but we aren't talking like an overdrive that'll self destruct. if you can run it, you should. If you don't, it isn't detrimental, but it will cause a slightly shorter tranny life. |
01-04-2009, 05:27 PM | #10 |
"THE GREEN GOBLIN"
Thanks Longhorn Man It looks like I have to invest in a Automatic Transmission Kickdown Kit in the near future once I get it driveable... And here I thought it was a temp sensor
Petey-pablo
