What would make a "new alternator" not charge? i have a new battery,a new voltage regulator, new battery post,& a good starter. this dilemma is driving me crazy!!!
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
Son of a gun
Re: New Alternator
Do you still have a voltage regulator (have not converted to internal reg yet)? If so, replace it too
EDIT*********** Never mind...I am blind apparently, I now clearly see you said voltage regulator... I second Krue, have the parts store check the alternator.
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 01-04-2009 at 01:07 AM. |
Designated A-hole!
Re: New Alternator
If you bought it from a chain store it may just be a bad alternator.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: New Alternator
This is my third NEW alternator,i got the upgraded 1 & the standard 1. i put a NEW voltage regulator on it too. It seems as though the NEW alternators is not charging & i dont know why!! ...this has become bothersome. could it be wires aren't connected?? Im
#5 | |
Active Member
![]() Join Date: Jul 2007
Re: New Alternator
Question: Are you checking the voltage across the battery connection to see if the alternator is charging? My gauge was messed up for a while and it wouldn't show it was charging. It turned out to be a grounding issue. Make sure all your grounds are good -engine to frame, radiator support to battery, etc... |
Re: New Alternator
Battery is not getting charged from several NEW alternators i've tried. so the first thing i will check is the ground. The guy before me never used the ground on the alternator,nor the two prong plug that goes in the back of the alternator. he had them folded & taped down. I have no earthly reason why. it was running fine but now its a pain in my derriere! i've spent enuff money on this & makes me wanna get rid of it
Re: New Alternator
i have a 283 small block chevy
#8 | |||
Union Electrician
Re: New Alternator
check the truck tech FAQ board and you will find the internal regulated alt conversion, and you should be able to determine what the problem is. A very worthwhile upgrade and should help with your issues as well...
Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Re: New Alternator
I had this happen....got a bad alt and a bad reg the same day. I got pissed and checked into the thread in the FAQ about upgrading to a Silverado Alt and eliminating the reg. Did that the very next day and never looked back.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 01-04-2009 at 10:06 AM. |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: New Alternator
One of the best upgrades for sure. Definately put a internally regulated alt. on there and all will be good again.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#11 | ||
Re: New Alternator
Is it still like this? If so, that is your problem. The regulator may be plugged into its connector, but it is not connected to the alternator. One of those wires "turns it on" and the other goes to the gauge on the dash. If you just have the "output" wire going to the battery, you will get nothing.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Re: New Alternator
yup plus one need to connect the alt. to the harness. Otherwise you will not charge the batt. Actually i don't think anything electrical in the truck will run for long untill the batt. goes dead for good. Sounds like thats the fix for now.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!! 70 Chevy C-10, 355, th400, 3.73's 2/4 drop |
#13 |
Re: New Alternator
If you start it and undo the batt does it stay running? If not hook up the plug in for the alt. and try it again. If it does thats the issue. You may need a new batt. anyway though.
#14 |
Parts and more parts
Re: New Alternator
That two prong plug is what creates the electrical field for the alternator to cut and create electricity. It needs a source to get the generation started. You may be able to draw some info from the website below.
http://www.bcae1.com/charging.htm |
