Old 01-04-2009, 01:12 AM   #1
Square84
I don't think these pills work
Square84's Avatar
tbi to carb help
i've got a 90 burb that has a 350tbi motor but i want to change that to a carb. i know ill have to change the intake, distributor, and fuel pump. anybody have any knowledge on this kinda swap i would appreciate the help. Also where would i get the power supply to the older style coil in the cap(it currently has a coil seperate from the distributor). thanks in advance.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 01-04-2009, 01:56 AM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: tbi to carb help
Dude, why do you want to do that? That is kind of a huge step back in technology. I would suspect there will be many people lined up to trade you everything you need to go to a carb in exchange for your TBI stuff.
Back to your question, I believe you would just use the same keyed-on battery power supply wire to fire the old style HEI distributor as what is already connected to the coil you have now.
I'll trade you a big cap HEI for your stuff....I don't have a carb laying around though as I threw them all away!
DirtyLarry is offline   Reply With Quote
Old 01-04-2009, 07:43 AM   #3
cjracing15
cjracing15's Avatar
I will second that, WHY? I have just about completed the oppsite converstion (carb to tbi). TO get back to your question, as DL said you can use the big pink wire on your coil that is on your sub right now. As far as the fuel I gues you could use a regulator to bring down the press of the in tank pump for a carb, or If your block has a fuel pump block of plate all you have to do is swap out the cam to a carb one and mount a fuel pump and fuel pump rod on the block. Also you will have to put a carb pickup in the tank if you go that route. Also change the intake. ( I have a eldebrock intake for tbi heads if you go this route just pm me). But I would be cuirous to why you want to do this swap?
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 01-04-2009, 11:52 AM   #4
Rollinsqrbdy
Rollinsqrbdy's Avatar
I dont have an answer to ur question but, i also like carb better. So much easier to work on and its old school. Good luck with the swap
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 01-04-2009, 01:29 PM   #5
us111
hello.i have a carb'd 5.7 out of a 99 escalade and love it.people have
had trouble trying to use the in tank fuel pump and some have made
it work.i just put a electric fuel pump on frame rail into a regulator
that runs around 3psi into a 650 edel carb and it flies.other than that
like u have said get an intake,distributor and your good to go.other thing i just remembered i dont know about 90,but on my 99 motor there is no timing
tab.lot of different ways to fashion one which is alot easier with engine out.
havent made one for mine yet,just tune her till she runs the way u want it.
i just like old school myself.
us111 is offline   Reply With Quote
Old 01-04-2009, 11:57 PM   #6
Square84
Square84's Avatar
i am just thinking of this swap right now because every other week i am having to mess with the tbi unit. my truck is carb and i never have to mess with it. granted its a little harder to start thr carbed truck in cold weather but it runs so much better than the tbi. i have replaced the iacv twice and the tps three times and put a new diaphragm it the pressure regulator and it still idle erraticky and has trouble starting.with the carb i just pump gas twice and turn the key and it pops off, also the carbed motor is a rebuilt 305 and it runs circles around the crate 350tbi with less than 9000 miles on it. if any body has any suggestions on the problem i may consider keeping the tbi setup.and thanks for the replies.
SQUARE84
90 SUBURBAN
