Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-04-2009, 03:02 AM   #1
custom72c20
custom72c20's Avatar
2 piece drive shaft help!!!!
Im currently swapping a 454 big block and turbo 400 trans into my 72 c20. All i have planned to do is put big block frame towers , cut factory trans mount off of the frame, and then position and bolt the new tranny crossmember on. Sorry for the run on sentence, but is there any way i could run a 1 piece driveshaft instead of a 2 piece?
I was wondering if I would :
- not be able to run due to it maybe hitting the trailing arm crossmember (even though my truck has leaf springs.)
- be able to just shorten the drive shaft and run CPP's heavy duty carrier bearing.
The motor going in has about 550 horsepower and Im also running a 3,500 stall converter.
I don't know which way would be easier, cheaper, or the best bang for the buck.
CAN YOU PLEASE HELP ME!!!!!!!!!!
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 01-04-2009, 03:05 AM   #2
custom72c20
Re: 2 piece drive shaft help!!!!
Here's a link to CPP's Carrier Bearing. Its the billet one in the picture. All help is appreciated. Thanks
http://www.classicperform.com/Store/...ruck/CPSSD.htm
Nick
Old 01-05-2009, 12:24 AM   #3
custom72c20
anyone?
Nick
Old 01-05-2009, 08:25 AM   #4
djracer
djracer's Avatar
I don't have any experience with long beds. 71 drag truck should be able to help.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-05-2009, 11:58 PM   #5
custom72c20
ok thanks. Hopefully he will chime in.
Nick
Old 01-06-2009, 08:10 AM   #6
djracer
djracer's Avatar
Pm him or Big jim if you don't get a response.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-06-2009, 06:16 PM   #7
nxtruck
nxtruck's Avatar
I swapped from a 2-piece shaft to a 1-piece shaft without any trouble. My 1-piece shaft is 3 1/2" in dia. and had plenty of room going through the crossmember. If everything is positioned anywhere close to stock, you shouldn't have any fitment problems, as far as room for a 1-piece shaft goes.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 01-06-2009, 10:56 PM   #8
bigjimzlll
bigjimzlll's Avatar
With my LWB truck I went to a 1 piece for a while. I moved the engine back as far as possible and used a long tail shaft th400. I had the shaft made from 3.5" .120 DOM tubing. .It worked ok until I started going fast. It started to "whip". I'm using a 2 piece now. I'm using a shaft made like monster trucks.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-07-2009, 12:08 AM   #9
custom72c20
Can you explain what you mean by "whip"? Would you recommend running a two piece or one piece driveshaft with my 500 horse big block. I just don't want to break anything. Thanks for the input.
Nick
Old 01-07-2009, 01:55 AM   #10
LuckyHenriksen
LuckyHenriksen's Avatar
I also have these same questions, glad someone is answering! Is that CPP carrier bearing a good idea?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 01-07-2009, 10:16 AM   #11
bigjimzlll
bigjimzlll's Avatar
If your DS isn't turning 6500 rpm you should be fine with a one piece. When you go longer the shaft has more chance of becoming unstable. If you have a 1/2" wood dowel that's 1 foot long it's difficult to bend, but if it's 2' it bends easier.
I thought my one piece was fine until I noticed scarring on the shaft and rubbed areas where it went through the rear cross member.
It's all about the critical RPM the SHAFT sees. Your engine will see 6500+rpm but the shaft doesnt...unless your running 130+mph
Anderson,CA
Old 01-07-2009, 10:36 PM   #12
custom72c20
Thank you for the info. I'll probably just go with the one piece the motor redlines at around 6,300 so it should be fine. I hope.
Nick
Old 01-07-2009, 11:13 PM   #13
LuckyHenriksen
I have a stock 2 piece shaft, and plan to throw some good power at it. Any advice on semi-cheap upgrades that will keep it together?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-08-2009, 12:27 AM   #14
custom72c20
I think that CPP carrier bearing would be a good purchase for you IMO. It looks pretty stout and is cheaper than having a new driveshaft made.
Nick
Old 01-08-2009, 08:42 AM   #15
Lx3
Lx3's Avatar
Try a search for Inland Empire Driveline. They have some good stuff.
Lx3 is offline   Reply With Quote
Old 01-08-2009, 06:17 PM   #16
meansting04
meansting04's Avatar
Plus one used it on my 2004 GTO. Worked great. A little priceeee. Well worh it.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 01-08-2009, 11:18 PM   #17
custom72c20
Im going to get a driveshaft from them. Cool thing is that they're only 45 min from my house.
Nick
Old 01-09-2009, 02:29 PM   #18
meansting04
good. You will be glad you went with a well know name. I loved mine. Worth the $$.
Old 01-10-2009, 07:29 PM   #19
Lionc68c10
Lionc68c10's Avatar
good idea
Lionc68c10 is offline   Reply With Quote
Old 01-13-2009, 05:24 PM   #20
kcjones
I wish I was a cowboy
kcjones's Avatar
There's a great driveshaft shop near where I live, Driveline Service of Santa Rosa (I think they're in Fresno and Sac, too), and they recommended I stay with my 2 piece, low power motor or high, reason just as BigJim said - the longer the shaft, the more vibration and tiny imbalances affect the shaft. Even at low rpm with a near perfect balance, every drive shaft is sending some rotation torsion through the ujoints. Because it is relatively minimal, the ujoints, yoke, and center bearing will absorb this vibration and you drive on down the road. But, double the length of that shaft, and the forces at work, even with that near perfect balance, will apply double the power of those same forces. So, instead of good ujoints under 400+HP at 100MPH for many thousands of miles, you have many fewer miles under those circumstances but with a longer shaft, even if the diameter is larger.
SWB and 3 or 3.5" shaft, no problem. Our LWB's require a 72"+ shaft with short tail TH400 and stock motor position.
Another factory is the weight of the shaft - longer shafts must have larger diameters to correctly spread the force of power being applied, and hence, are heavier. The heavier the shaft, the more engine power absorbed and the more rotational torsion applied.
2 piece and billet carrier are a good bet for a LWB.
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
