Old 01-04-2009, 05:42 AM   #1
meansting04
meansting04's Avatar
2 inch drop springs, wheel geometry
So after some searching and reading the question i have is with a 70 with all stock suspension and drum brakes can i run a two inch drop spring in the front and still be able to properly align my wheel camber and not chew my front tires to pieces? If so is there any addtional parts needed. If there are people running this setup are you guys running adjustable camber kits? I know that spindles are prefered, but i am not ready to commit this kind of money right now to swap to disc. Thanks in advance for the help.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 01-04-2009, 08:20 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 2 inch drop springs, wheel geametry
Unless your suspension is greatly worn already, you should be able to get the camber back out to where it needs to be with the 2 inch springs. I usually run 3 inch springs and have always been able to (barely) get the camber set back right.
Eventually, you run out of bolt room for the stack of shims, but I never have yet. Some guys say they can't get enough shims in place to get it adjusted, but I suspect they have underlying problems with their suspension components.
Old 01-04-2009, 08:24 AM   #3
meansting04
Well i am replacing the ball joints upper and lower, tie rod ends, and shocks. anyhting eles you suggest before i get it an aligment?
Old 01-04-2009, 08:48 AM   #4
Tx Firefighter
Check your control arm bushings upper and lower, idler arm, and pitman arm for slop.
You should be good to go for many happy years of use after that.
Old 01-04-2009, 09:03 AM   #5
meansting04
Do you know how many degrees of camber two inches will input? Or how many shims i should add?
Old 01-04-2009, 09:05 AM   #6
meansting04
Or can i even get drop spindles for drums...anywhere?
Old 01-04-2009, 10:42 AM   #7
LONGHAIR
I don't think so....I would think that they would sell, but probably not enough to make it profitable. Most guys are looking to convert to disc anyway, so rather than spend the money twice, they just save for the conversion.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-04-2009, 11:32 AM   #8
meansting04
Ya kinda lookinf for a budget hot rod truck build. My drums work excellent and the are pretty much new. They are power so i don't have any problems with them and they see limited road time. I am just hunting for the right stance.
Old 01-04-2009, 12:38 PM   #9
meansting04
Re: 2 inch drop springs, wheel geometry
I guess i am looking for other guys running just drop springs in the front and trying to find out what problems/advantages (besides cost) there is. I am getting ready for a cruise and would like the pros and cons of this idea. I plan on running a 4" drop leaf in the back. So i guess before i go in this direction i need some sound advice.
Old 01-05-2009, 03:35 AM   #10
meansting04
anybody got anything??
Old 01-05-2009, 08:29 PM   #11
northern 85
northern 85's Avatar
85 swb 2" front drop springs 2" drop shackles no issues drives nice handles great.
northern 85 is offline   Reply With Quote
Old 01-11-2009, 12:04 PM   #12
meansting04
Thanks still waiting on my kits to get here but i got all off the ball joints and what not the other day so it wont be long.
Old 01-11-2009, 04:35 PM   #13
texanidiot25
Eat My Rust
texanidiot25's Avatar
I have 3 in drop springs on my '69, I'll let you know how far off stock the springs put them and what all went into getting it aligned in a few weeks when I goto do it. Though I have no 'before' measurements on my truck's camber, this should help you some.
texanidiot25 is offline   Reply With Quote
Old 10-17-2009, 04:19 PM   #14
steinepstein
Has anyone ever run taller ball joints? I heard of many of the guys over at lateral-g.net doing this to improve geometry.
steinepstein is offline   Reply With Quote
