Old 01-04-2009, 11:56 AM   #1
drewfever1020
is a?
one wire alternator good or bad to have?
lmk cuz im thinkg about getting one!
drewfever1020 is offline   Reply With Quote
Old 01-04-2009, 12:04 PM   #2
LONGHAIR
Re: is a?
You are much better off with a traditional 3 wire internally regulated alternator. There is a very good explanation Here
BTW, it is a very good idea to make your post title an actual question, related to your actul question is best.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-04-2009, 01:27 PM   #3
Gray Ghost
Gray Ghost's Avatar
Re: is a?
I swapped in a '87 Silverado 94 amp....didn't have to buy a kit either. Works like a charm. You can find the article in the FAQ section.
All you have to buy is the alternator and wire a couple of leads together at the regulator plug.
With 94 amps you can run everything you need to without worrying about the amps drawing down too low.
I know nothing about the kit, but I do know that my one wire beats the pants of any stock alternator setup regardless of the number of wires. 94amps is simply much better than 62!
PS....the alternator I used is available anywhere. I bought mine at O'Reilly's
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 01-04-2009, 01:38 PM   #4
EyeH8the24
EyeH8the24's Avatar
Re: is a?
been running one on my dd almost a year now.no problems.charges great .just have to remember to rev engine past 1000 rpm to kick it on .i dont know if they are all that way but mine wont start charging till i get over 1000 rpm then it charges all the time
EyeH8the24 is offline   Reply With Quote
Old 01-04-2009, 01:53 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Re: is a?
I have a 100 amp one-wire alternator and love it. Had it for 4 years now, and no problems, plus less wires = cleaner engine compartment. I see them on all the high dollar hot rods, so that is good enough reason for me to have one. With the extra amps, you will have no problems with running other accessories as well.
leddzepp is offline   Reply With Quote
Old 01-04-2009, 02:10 PM   #6
454_72_4X4
454_72_4X4's Avatar
Re: is a?
I prefer the one wire alt myself. It's simpler, eliminates a few wires, and performs just as well as the three wire.
While there may be some merit to the idiot light not working on the one wire and the "remote voltage sensing" of the 3 wire, most of the other info in that article is bogus.
Right here is the first clue;
does not sell alternators, and we never have. Therefore we have no reason to slant this story.
While they might not sell alternators, they are tryin to sell an alternator wiring kit.
I can't remember exactly how to wire a 3 wire right at the moment, but I know it can be done for a couple bucks. IIRC, all ya need is a few feet of wire and a couple spade connectors. I'm guessing this would be their "kit" they're selling for 28 bucks.
Any 10SI, (and probably the 12SI too, but I can't say for sure), can be converted to a one wire alt in a few minutes by just swapping out the normal internal voltage regulator for a "self exciting" regulater. That's all there is to it. Everything else is the same.
I just did this conversion, (again), 2 days ago for the alt on my motorhome.
If anybody needs/wants pics of how to do it, I haven't put the alt back on yet. I'd be more than happy to split it apart again and snap some pics.
The normal regulator is still layin on my welder as a matter of fact! LOL
If ya have a friendly alternator rebuild shop locally, just go in and ask 'em for a self exciting regulator. The last one I bought cost about 12-14 bucks I think. I carry an extra one in the glove box just in case it fails. But I've been using the "one wires" on various vehicles for close to 15 years and never had one fail yet.
To be sure ya get a self exciting regulator, the part number on it will have a SE in it.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-04-2009, 02:21 PM   #7
drewfever1020
Re: is a?
doesnt the one wire alt come with an internal regulator tho?
Old 01-04-2009, 02:23 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Re: is a?
I also recommend a local alternator shop whichever route you choose...I have always had problems in the past buying from chain parts stores when it comes to alternators. My local guy is the one who recommended a one-wire alt, and also wound it so I have 100 amps output.
Old 01-04-2009, 02:34 PM   #9
drewfever1020
Re: is a?
ya i know a place were to get one with 100 apps!
but how do i hook it up?
Old 01-04-2009, 02:36 PM   #10
drewfever1020
Re: is a?
oh ya and how will itwork the the og harness?
i dont think ill be using the harnees to connect to the alt so wich wires will i be eliminating?
Old 01-04-2009, 02:38 PM   #11
454_72_4X4
454_72_4X4's Avatar
Re: is a?
Yep.
And to look at the regulators themselves, (3 wire internal vs the 1 wire internal), they look identical. The only difference is the SE on the part number. The 1 wire even has the 2 spade connector terminals, (that don't get used). I've never figured out why they went ahead and put those terminals on the SE regulators.... Doesn't make much sense to me. LOL
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-04-2009, 02:41 PM   #12
454_72_4X4
454_72_4X4's Avatar
Re: is a?
With the 1 wire?
You'll be eliminating basically all the wires that go to the original alt. and regulator.
Ya just run one wire from the post on the alt to the pos (+) post of the battery.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-04-2009, 02:58 PM   #13
drewfever1020
Re: is a?
so i run a wire to the positive post but what happens the the wire that goes from the starter to the battery?
Old 01-04-2009, 03:10 PM   #14
Senator350
Senator350's Avatar
Re: is a?
starter-battery=nothing to do with this.
in a three wire alt there are three wires to your old alternator, a constant hot, a constant ground, and an ignition hot. anything else electric you want to run under the hood? you can use your old alt wires
lets put a tech response here in case this thread shows up in a search.
what are the wires that go to the original alternator? where do they go? link to a wiring scheme?
RN U OVR
Senator350 is offline   Reply With Quote
Old 01-04-2009, 03:18 PM   #15
Senator350
Senator350's Avatar
Re: is a?
found link to this in first page of search results for "alternator wiring"
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
RN U OVR
Old 01-04-2009, 03:56 PM   #16
454_72_4X4
454_72_4X4's Avatar
Re: is a?
There's that $28 "kit"! 4 or 5 connetors an a couple inches of wire. Hahaha
It's been to many years since I converted my 72 to the 1 wire to remember what I did with the original wires, but I know they're gone...LOL I think I traced 'em back to the firewall plugin and removed 'em from the harness completely.
I remember replacing the resistor wire for the distrubutor, (ignition/coil), power with a normal wire when I swapped to HEI. I'm pretty sure I removed the alt wiring at the same time.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
