welding heater control
I am looking to attach my heater control leaver to the cast chrome housing but there is no way to re-attach it and I was going to do a small tig weld on what was left of the rivot but does anyone know what the cast material is
made out of any help would be great |
I am a Referee of life.
Re: welding heater control
It's called "pot metal".I really don't know if you can TIG it.I doubt it but it never hurts to try.If it doesn't work they make a kit to repair the broken levers.It's made of steel.They only take a couple hours to install and from what I can tell they will never break again.In order to make sure you have a good repair remove the cables and clean/lube them so they operate smoothly.I cleaned mine in a parts washer and then laid them in my oil drain pan where I had left oil.It's been 6-7 years and they still work well.I do spray some graphite lube in the ends of the cables regularly.
BTW Any vendor should carry the kit.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 01-04-2009 at 06:35 PM. |
Dave's not here, man
I agree with Panel. Mine broke off and I thought about trying to have it welded too. In the end I just replaced it. It didn't cost very much and wasn't too hard to do. If you do decide to weld it let us know how it works out for you.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
72 GMC
The Older Generation
I get the impression that he is talking about the chrome face coming loose from the lever assembly.... If this is correct, you won't be able to weld it because it is pot metal as Panel said, and has a low melting point and it will just "blow" away. I have repaired these by drilling through the face of the unit, countersinking the holes on the outside, putting small flat head bolts in it and getting a new self stick metallic decal for the face. LockDoc
i've drilled and tapped and used a screw for repairing the levers had them work for years without problems
![]() Join Date: Nov 2008
You can try tig welding it with no filler rod, or try brazing which would be plenty strong.
