Old 01-04-2009, 08:04 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Building a dually my way....
Well fellas, I'm doing a bit of a project and thought due to the depth of it all I would go ahead and post a build thread.
Basically, I have always wanted a dually truck to use as my work truck. I looked at length and couldn't really find a decent truck to build. I've been watching the buildup thread of 67 C30 and his truck with hips and it's not exactly what I need. I wanted the final product to be a cab and chassis, or a narrow rear truck.
Ultimately I decided that the 3/4 ton truck that I have now offered enough positive attributes that I decided it was worth the trouble of converting it to a dually.
To start with, its a highly optioned Super Cheyenne with a big block, TH400, Dana 60, tilt column, air conditioning, and leaf spring rear end.
In my research, I was told that converting the rear end was simply a matter of bolting on the wheels and making room for them to fit under the bed.
So my first purchase was 4 dually wheels. When I went to fit them, the inner wheel would not clear the brake drum. It fell about 7/16 of an inch short of seating onto the hub.
I am pretty attached to the rearend I have currently since it has a 300 dollar cover on it and new internals, including carrier, ring and pinion, and all bearings. I wanted to make this work without having to swap out the entire rear differential for a wider one.
So, what I did was order a set of 1/2 inch thick spacers off ebay. These would of course, coupled with dual wheels, require longer wheel studs.
I studied Dorman's website at great length and found a part number that is the same as my current Dana 60 studs, but greatly longer. So, off to the parts store I go, armed with my number. It took him 2 days and a lot of phone calls, but he came through.
(contd)
Old 01-04-2009, 08:08 PM   #2
Tx Firefighter
Re: Building a dually my way....
(contd).
This is the desired part number:
Comparison old to new:
Pressing them in place. They fit perfectly !
The final hub with new, longer studs :
More tomorrow night...
Old 01-04-2009, 08:13 PM   #3
Boog
laying low
Boog's Avatar
It all starts with a bolt doesn't it? I've had this idea in the back of my mind all along that you might be ending up going this route. I mean you've already got the truck so why not? I wonder what's the deal with the wheels NOT mounting up as said?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-04-2009, 08:19 PM   #4
Tx Firefighter
As I get older I don't believe much second hand information anymore and only half of what I see.
That's why I'm documenting this thing so explicitly. When someone asks a question in the future, I can say for sure, and offer picture proof of what it takes to do this job.
Old 01-04-2009, 09:42 PM   #5
Rokcrln
Rokcrln's Avatar
What size rim was it you picked up? Would a larger diameter have cleared?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-04-2009, 09:46 PM   #6
Tx Firefighter
Normal 16 inch late 70s dually wheels. Actually made by Accuride.
A larger wheel would definitely have made the difference. If I would have committed to later model 17 inch dually wheels, this would not have been an issue whatsoever.
Old 01-04-2009, 09:59 PM   #7
krue
Designated A-hole!
krue's Avatar
Looks like another FAQ when you're done.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-04-2009, 10:49 PM   #8
Always like watching your projects TX, so I am here to see what goes too. I like your idea. I have thought about it at times also.
Old 01-06-2009, 09:48 AM   #9
Tx Firefighter
Slight delay on this project.
I ordered a blast cabinet and am ordering a powdercoating gun today.
I want this stuff pretty nice, so I will wait a week or so for the new tools to arrive. Next parts you see should be powdercoated instead of painting.
I should have progress pictures after this weekend though.
I have a good bit of parts arriving every day, so progress shouldn't be held up waiting too much.
Springing for those 6 new tires is gonna sting the old pocketbook though.
Old 01-07-2009, 12:42 AM   #10
custom72c20
custom72c20's Avatar
Nice truck and build. Can you tell me where you got that Dana 60 cover. Thanks and good luck on the build.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 01-07-2009, 07:58 AM   #11
Tx Firefighter
The cover is from Maghytec.
It uses an o ring for seal rather than a gasket or silicone.
It also has a built in dipstick to measure the fluid level whenever you want.
Old 01-07-2009, 08:56 AM   #12
Rokcrln
Rokcrln's Avatar
Tx I saw this truck on a Job site Monday and popped a few pic's for you (sorry Camera Phone) but it was a perfect example of a nice dually/work/daily driver. I would like one of these one day
Kevin
LFD Inc.
Old 01-07-2009, 04:14 PM   #13
Tx Firefighter
Kevin,
I sure hope I can figure out where to get the cash for a set of Alcoas like that guy is running. I'm currently more on a paint my stockers or run simulators kind of budget, that is, about 900 short of Alcoas.
I'm bracing myself for buying six tires for this truck already. Tires and Alcoas would run about 2000 bucks total.
Today's progress was getting the back side done.
Everything went smoothly after I got all the parts here. GM Dana 60 brake parts are getting very hard to come by nowdays. The hub seals were particularly elusive.
Pardon the masking tape, the paint on the axles was still drying, so I wanted to make sure no dust got inside the rear before I put them back in place.
Brakes done :
Brake drum installed:
Spacer in place :
Tomorrow starts cleaning and rebuilding the front spindles, brakes, and rotors. They are a greasy mess right now. But, since they are 84 vintage, I expect the brake parts to be easy to source.
Old 01-08-2009, 12:32 AM   #14
custom72c20
Thanks and nice progress.
Nick
Old 01-08-2009, 12:47 AM   #15
fbird68
fbird68's Avatar
Hey TX. Duallies are cool. I really like em when they are tucked in under the fleetsides.
I will be following along on your mods.
I have some spacers that are about two inches thick for my Dana 80 and they bolt on to shorter studs on the hub.
I may use them to keep the 4' between the tubs if the wheels don't stick out too far for my liking.
Keep the updates coming.
Richard
fbird68 is offline   Reply With Quote
Old 01-08-2009, 03:47 AM   #16
67_C-30
I have a radical idea!
67_C-30's Avatar
Richard
To maintain the 4' between the tubs means the outside tire sticking all the way out of the fender. I found when building mine that they either have to be tubbed or have outside flares/fenders to look right.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 01-08-2009, 03:50 AM   #17
67_C-30
67_C-30's Avatar
How far is the inner wheel from the wheel tub on it? Even with my wide rearend there's not much distance between the inner wheel tub and inner wheel. My hub sticks out past the bedside. I was almost certain you would have to run bigger spacers (like 2" or more) to have enough workable clearance with 3/4 ton rearend. The pic below was mine was just the inside wheel mounted.
I only mention this to save you some heartache when you get to that point. I didn't see if you said you were going to widen the inner tubs like 72Freak did on his truck. If you didn't have tires on the rims when you mocked it up, you may want to double check it.
My trucks
Old 01-08-2009, 04:03 AM   #18
67_C-30
67_C-30's Avatar
Kevin,
When you get the factory rotors off your truck, let us know if the spindles are the same. I have been told by 2 people that you can just put 1 ton rotors on '71 - '87 3/4 ton spindles, but I don't know that for fact. They say you can just swap rotors and go, and I'm curious if they that is true. Thanks!
My trucks
Old 01-08-2009, 08:16 AM   #19
Tx Firefighter
Will do on the rotor swap info. I was told that too.
The only reason I'm doing it like this is that the 84 front brakes are much larger pads and calipers than the 72 stuff is. I'm hoping for good stopping power, as this truck will be worked a lot and I need good brakes.
Old 01-08-2009, 08:21 AM   #20
Tx Firefighter
And, by the way, 67 C30, I can't help but notice that your build thread has fallen pretty far off the front page. You're not sitting on the couch watching TV lately are you ? We need a progress fix !
Old 01-08-2009, 10:37 AM   #21
ERASER5
ERASER5's Avatar
Tx Firefighter, looking at your last picture, when you got those front spindles, did you uh, scalp them?
Is this a hatchet job?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-08-2009, 10:43 AM   #22
Tx Firefighter
It takes some serious muscle to hack through a frame rail with that little hatchet. You should feel my handshake though. Lumberjacks got nothing on me.
Old 01-08-2009, 08:23 PM   #23
Tx Firefighter
Well, today's installment should be called "How I know Kevin is quirky".
First, I must say I HATE, HATE, HATE to pay anyone to do anything for me. If I can't do it myself, it doesn't usually get done. My girlfriend learned this when I did my own stitches to avoid an ER visit.
Anyway, I spent time today breaking down my old wheels and junk tires off the donor trucks. This is how I break the bead on my tires. I use my trailer tongue and a piece of steel against the tire. Just screw the jack up and the weight of the trailer will push the tire off the bead.
After that, a couple of long Snap-On prybars and Bob's your uncle, the tire is off.
After doing all of those, I spent the rest of the day cleaning up the front spindles.
My bead blast cabinet is due to arrive tomorrow and my powder coat rig on Saturday. If I can find an oven real fast, I will powdercoat the spindles and rotors.
Hopefully, another progress update this weekend.
G'day,
Kevin
Old 01-08-2009, 08:27 PM   #24
Primered_69
Primered_69's Avatar
You know I am disappointed.
The last time you showed a picture of your tire changing abilities...you did it in sandals...I guess you are getting high class now...you probably even used safety glasses too.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 01-08-2009, 08:30 PM   #25
Tx Firefighter
Michael, I'm not gonna lie. I am starting to feel my age. Dismounting 6 old dry dually tires about did me in today. After that, I just sat on a stool and wire brushed a spindle.
The day may come that I pay someone to do this stuff for me if this keeps up.
By the way, no sandles or safety glasses. Today was shorts, tee shirt, and Nike shoes. I'm definitely getting soft as I get older.
