72 chevys 4 life
On a truck i just got i finally got the motor started up and poured in some tranny fluid. I filled it up to the full line then when i was going down the road it started leaking out. Then when i pulled the dipstick out a lil bit it looked like a volcano of tranny fluid. What could cause this?
I dont call it being young and dumb....I call it young and havin fun ![]() |
Re: tranny fluid coming out of the dipstick hole?
i would have to say the vent on the side of the tranny is plugged up, that would be my first guess, the vent should be right by where the lines go in the side of the case, check that
72 chevys 4 life
yeah thats kinda what my dad was thinking..im hoping thats all thats wrong is it pretty easy to pull out or however you do it to clean it or replace? i have a th400
![]() Join Date: Jan 2008
My vent was a little tube on top of the trans. A little shot of air and the problem was fixed, but too much air will blow the fluid back.Good luck
Like others said check the vent pipe.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
72 chevys 4 life
yeah ill try that so is it on top of the tranny or on the side? pictures?
here is a pict of where mine is.....
72 Chevelle Club
Here's mine on my 400th Bob
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
Designated A-hole!
If you filled it to full with the tranny cold you may have over filled it. But I would check the vent tube also, especially if you have dirt dobbers in your area.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
72 chevys 4 life
yup we have mud dobbers everywhere...as a matter of fact i pulled quite a few of nests off my motor...should i try to blow the dirt back into the tranny vent hole/tube?
I've been having a similar problem with my tranny. Guess I should try cleaning out the vent on mine too. Thanks guys.
i'd try just using a thin piece of wire running it up and down thru the vent tube
#13 |
Designated A-hole!
Cdowns is right, try not to get anymore dirt into the tranny than you have to.
#14 |
if i were you i would really try to take the tube out of the case to get it all cleaned out, be sure not to break it off in the case but just twist on it some and it should come out, make sure you dont blow back into the trans though. good luck
#15 |
You didn't mention if you added the fluid with the engine running or not. Just a thought, but the engine must be running while adding fluid to level, or you will overfill it. Also, I put it in gear a few times and recheck the level.
1997 GMC Sierra Ext 1965 Mustang |
#16 |
72 chevys 4 life
yes it was running when i put it in lol wish me luck ima do it tomorrow
#17 |
72 GMC
i WISH YOU GUYS WOULD CLEAN UP THOSE
PARTS A LITTLE BIT BEFORE YOU POST THOSE PICTURES. |
#18 |
![]() Join Date: Sep 2005
why?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#19 |
72 GMC
That was sarcasm.
Did you see the pictures ? |
#20 |
I'M TRUCK CRAZY!
#21 |
I'M TRUCK CRAZY!
I don't have a tube on my th350.... just a hole. Didn't know there was a tube for it. Mine works fine. Just need to fix the other leaks on it. hahahahaa
#22 |
next time put a smillies or something like
