![]() Join Date: Nov 2007
ADDCO Sway Bar Install 65C10
I installed a sway bar in my 65 this weekend. I have exhaust interference problems on the rear one so that will have to wait.
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Re: ADDCO Sway Bar Install 65C10
Here is the rest of the install.
TR
1 thing at a time is progress.
Nice work and write up.
Alan
Philippians 2:14-16 |
Hey Y'all!!
Good job on the install and write up TR65.
Looks like a nice sticky! |
TR,
mad props to ya for the write-up and install! ![]() ![]() niiice!!!
![]() ![]() Last edited by joe231; 01-04-2009 at 11:14 PM. |
Nice clean install.Very informative write up and great photos/angles. (A+)
Thanks for the kind words guys.
Alan, Go figure. My install required the rivet removal. Your video was great. I would appreciate some more instruction! TR
#8 | |
Alan
Nice write up, I've been wanting to add one of those too.
Question: Would it have worked to skip the angle bracket on the a-arm, and move the whole bar mount back some inch or so, so the link on the a-arm goes through the top surface on the a-arm itself? (Thus eliminating the angle bracket, ie one more piece that might fall off some day.) |
283 Drama Queen
![]() Join Date: Dec 2004
Wow.
![]() That's the way to document a job. 1st Class. Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
Resistance is Futile
I think you would have avoided the bumper bracket clearance issue with the use of either factory stands or the aftermarket lowered stands on the frame mounting points. Im not familiar with this kit or what your whole plan involves, just thought I'd mention.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Hey rickf,
This bar is too wide to mount directly on the A-arm, it would run into the rubber bumper mounts. Good idea though. Hey Protrash64, I could have just put a 1/8" spacer under the frame mounts but the interference just required less than 1/8" ground off the bracket flanges, 5 minute job. Thanks for the input. TR
#13 |
First one Ive seen mounted w/out the stands.......I would grind before unbolting the bar. too!
#14 |
Well, I have driven the truck with the front anti-roll bar for a while and I can say that the difference in handling is remarkable. Without the bar the truck seemed like it was going to roll over going around almost any sharp curve at speed. Now she stays flat. I would highly recommend adding a bar to any truck that doesn't have one, it is the best upgrade I have made.... Well maybe disc brakes were better. The truck is much more pleasurable to drive.
I talked to a professional test driver today and he reminded me that while the handling is much improved the truck will still turn over at about the same speed around a corner as before. There is a benefit in emergency events like a double lane change around that alligator in the middle of the road. Since you don't get the roll momentum the truck is more likely to keep the shiny side up. Next up, the rear bar. TR
#15 |
Junior Member
You just answered my question...the test is in the driving. sounds like this is an improvement every owner who will be driving theirs should make.
Great job on the write up. |
#16 |
Is it possible to use a stabalizing bar from a 1973-87 on a 1965 truck instead of buying the kit from brothers?
Drew |
#17 |
Registerd User
#18 | |
Drew |
#19 |
Registerd User
In 2 weeks or so keep an eye on my build and I'll post it. Truck is still in the body shop.
#20 |
Registerd User
#21 | |
sam |
