![]() Join Date: Mar 2005
my new project
i'm getting close to being able to drive and use my latest truck build. i built this mainly because i have a new work truck (furd)i drive almost every where, but i'm not allowed to pull trailers with it, etc. and because i sold my '97 gmc z-71 because it sat for months at a time. i needed a tow pig and something i could use and not scratch my '67 up. it started life as a '70 3/4 ton,sb,t-400,a/c,pb,ps. i purchased it from the 2nd owner,he purchased in '72. i moved the body over to a '72 gmc 1/2 ton lwb leaf spring frame. to power it is a '98carb'ed vortec 350,t-400,3.08 12 bolt w/factory posi..i installed a blazer tank and '05 chevy seats. the cab has a lil' more rust than i would like but it will suit my purpose just fine.should have everthing done and driving it by the end of the month. rusty
Re: my new project
more pics
Re: my new project
even more pics, because i know you like them
Why does it taste purple?
Re: my new project
Me likey. Nice pics
laying low
![]() Join Date: Mar 2001
Re: my new project
Yep, that ought to get it done and save the stepper too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Its always something!
Re: my new project
Lookin good! Decatur swapmeet is just around the corner.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed ![]() ![]() Member of the patina club |
![]() Join Date: Aug 2008
Cool rig. Just curious, though...If you are building a rig to pull trailers, why did you swap from the 3/4 ton gear to 1/2 ton?
My current "puller", 93 GMC 3/4 ton I bought with a blown motor for $800, swapped in a "free" (after I parted the wrecked GMC truck it came out of) 97 Vortec 350, still TBI, LT4 cam, Crane roller rockers, Comp Beehive Springs, new ram clutch/ TO bearing press. plate from EBAY for $75, NV4500 5 speed, 14 bolt full floater 4.10 posi out of green truck in picture is below, along with its eventual replacement, the 72 GMC Super Custom 3/4 ton 4x4 which will eventually get a 355/ TH350. I already scrounged two good OEM fenders, grille and radiator support! Who am I kidding. I will probably keep them both! I have a "thing" for GMC's. They are "PROFESSIONAL GRADE", you know! ![]() Last edited by WIDESIDE72; 01-06-2009 at 10:37 PM. |
Re: my new project
When is the Decatur swap meet?
Sorry for the threadjack Last edited by mycool72; 01-06-2009 at 11:01 PM. |
Tot Roddin'
Re: my new project
Great looking project!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: my new project
Decatur is usually in Feb right? This is one reason I have never gone....wayyyy too cold up there for me!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
![]() Join Date: May 2002
Re: my new project
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
RIP BigDaddyDave ~7-23-09~ You will be missed~
Re: my new project
Good looking truck.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
#13 |
ASE master tech/machinist
Re: my new project
Looks fantastic. If you ever need anything, I'm not too far from weatherford. I have tools and parts.
#14 |
Re: my new project
[QUOTE=WIDESIDE72;3070918]Cool rig. Just curious, though...If you are building a rig to pull trailers, why did you swap from the 3/4 ton gear to 1/2 ton?
i'm not pulling houses. the 1/2 ton z-71 i sold so i could build this one pulled plenty good. the heaviest load i pull is a full size truck and 3-4k lbs of scrap iron on a 16-18' trailer.i've had my share of 1 & 3/4 tons, diesels,bbc, 4.10 gears,4 speeds, and the like. you had really be needing to pull alot and often to justify putting fuel in and wear and tear on them. and this way i can allways upgrade the motor and gears if i really need to.... thanks for the comments......... rusty |
#15 |
Re: my new project
