Old 01-04-2009, 11:11 PM   #1
wwwbogercom@ll.net
7.00x18 wheels
bought a 69 c30 CST with 700x18 tires is this correct an option or has somebody put them on from an older truck?
wwwbogercom@ll.net is offline   Reply With Quote
Old 01-04-2009, 11:46 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 7.00x18 wheels
I have a 72 3/4 ton with 17" wheels. I am not sure about the 18". It may be possible on a one ton i suppose. Does your truck have the cst/30 emblems on the fenders? Any pics?
And welcome...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-04-2009, 11:56 PM   #3
wwwbogercom@ll.net
Re: 7.00x18 wheels
yes it has the emblems it is all correct but I dont know obout the wheels has bucket seat tach ac pb tinted glass built in STL MO Thanks
Old 01-05-2009, 12:17 AM   #4
too much stuff
Roadtrip!
Re: 7.00x18 wheels
Sounds like a pretty neat truck. I think we will need to see pics. Is it in nice shape? What is the engine/trans combo?
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 01-05-2009, 12:27 AM   #5
fine69
fine69's Avatar
Re: 7.00x18 wheels
I too have had a couple trucks with 17 inch stock wheels.
18's could be stock i suppose. Pics would tell us.
Welcome to the board.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 01-05-2009, 12:38 AM   #6
wwwbogercom@ll.net
Re: 7.00x18 wheels
than you lock ring wheels with 4 ovals around the out side my 47 ton has 8 holes
Old 01-05-2009, 09:36 AM   #7
Re: 7.00x18 wheels
That sounds like a special truck.A great find for sure.Yes,the 7.00-18/D (8 ply rating)tube types were an option (RPO R90).It should be listed on the SPID if from factory.Does the truck have the big 11,000# rear axle?(RPO H22)
Old 01-05-2009, 12:56 PM   #8
Joesjunk
Joesjunk's Avatar
Re: 7.00x18 wheels
Sounds cool, would love to see some pics!!!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 01-05-2009, 08:47 PM   #9
factorystock
factorystock's Avatar
Re: 7.00x18 wheels
The 8 hand hole 8 lug 18" split rim was around since the 40's and used up till the mid 60's, I think '68. The newer style 4 hand hole 8 lug rim 18" split rim is rare in this country, but was popular in Central and South America. It could have been a special order.
factorystock is offline   Reply With Quote
Old 01-06-2009, 09:02 AM   #10
Re: 7.00x18 wheels
The 7.00-18s were an option and it sounds like this truck was a special order.Sommeone knew what they wanted.Dual wheels were available in 16,16.5,18,& 19.5".Singles were available in 16 & 16.5".There were quite a few tire choices back then,too.Mostly load range rating differences.
Old 01-06-2009, 05:58 PM   #11
wwwbogercom@ll.net
Re: 7.00x18 wheels
thanks guys It does not have a code for the tire size the SPID it does have 4RO5RC DR WHEEL CONVERSION 4G60CA AUXILARY SPRING EQ GVW on door post is 10000 so i think it is a 7200 rear axle it has only one wheel cyl per side would like to know the diff ratio without taking the cover off but anyway its low
Old 01-06-2009, 06:03 PM   #12
wwwbogercom@ll.net
Re: 7.00x18 wheels
PS will work on the pics have to figure out how to post
Old 01-06-2009, 06:42 PM   #13
Re: 7.00x18 wheels
Just ask if you can`t figure the pictures.I used a tutorial in FAQ that tought me how to do it from Photobucket.I believe the 11,000# axle was the 5 & 10 pattern (5 front/10 rear) like medium duties.I thought I`d ask,even though I figured you would have mentioned the different lug pattern.
Which motor and transmission did it come with?It could be a 4.10 or 4.57 ratio if it came with a 350 and either the Chevrolet 4spd or Automatic.If it came with a 350,292,or 307 and New Process 4spd it would have 5.14s.
Old 01-06-2009, 06:53 PM   #14
wwwbogercom@ll.net
Re: 7.00x18 wheels
350 4bbl 4spd also has munual throttle option
Old 02-24-2014, 04:05 PM   #15
b.sharp
b.sharp's Avatar
Re: 7.00x18 wheels
my '68 has the 4 whole 8 lug 18" wheels. I would like to find some replacement tires for it or put the equivelent 16" wheel/tires on it. Anyone know what size 16" tire would be the same diameter?
b.sharp is offline   Reply With Quote
Old 02-24-2014, 08:06 PM   #16
factorystock
Re: 7.00x18 wheels
Stay away from the 16", way to small. The 3 piece 18" lock ring wheels are not my wheel of choice either. Go with the solid 19.5" dual type wheel that was the factory option in 1968. They are harder to find, but the 19.5" wheel and tire combo have the same diameter as the 18" lock ring tire and wheel combo. Make sure they are off a 1970 and older vehicle for the same stud size. Can be found on 1970 and older step vans, bread trucks etc.
Old 02-24-2014, 09:37 PM   #17
b.sharp
b.sharp's Avatar
Re: 7.00x18 wheels
I have a very hard time finding any older vehicles around here. It seems they are way off the beaten path or have been scrapped. My 65 c30 has 16" dollies from the factory on it. I had not seen the 18's until this truck. I will keep my eye out for the 19.5" wheels but will not hold my breath.
Old 02-24-2014, 10:34 PM   #18
truckdude239
truckdude239's Avatar
Re: 7.00x18 wheels
235/85r16
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
