Old 01-04-2009, 11:32 PM   #1
BAD4X4
BAD4X4's Avatar
Blazer roof rack For Sale
I pulled this off my 71 blazer. It is super sturdy but also very light weight. I figured I'd offer it up to the board first. I'm asking $125.00 Thanx Dana
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 01-05-2009, 12:16 AM   #2
CCCC
CCCC's Avatar
Re: Blazer roof rack For Sale
Is the rack rusty at all? Assuming that it is bolted through the roof (correct?) do all necessary brackets/bolts come with it?
I do not know the difference between a single wall and double wall top (help here - anyone !!) so must ask if it will work for both?
Thanks for any info.
CCCC
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 01-05-2009, 12:21 AM   #3
BAD4X4
BAD4X4's Avatar
It has surface rust where the paint has been scrapped. It just bolted through the top. I have all the hardware. I took the rack off my self. It is a great rack. Just not the look i'm going for. It only had 4 bolts in it, 3/8 bolts if I remember correctly. It should work with both tops.
Old 01-05-2009, 12:24 AM   #4
BAD4X4
BAD4X4's Avatar
pic on the blazer.
Old 01-05-2009, 12:39 AM   #5
Mint68
Mint68's Avatar
CCCC
Single wall tops have dome lights on the drivers side of the top. They bolt from the top of the lip down into the bedside. There should be nuts attached to the bottom of the bed rail on the inside, so the side panels dont need to be removed to remove the top. Stainles steel strips run on the inside of the lip underneath the bolts.
Double wall tops dont have exposed bolts from a "back seat" view. The side panels need to be removed to remove the top. Bolts run from the bottom of the bed side rail and into the bottom of the top.
Double wall tops were factory installed on 1969-1972 blazers. Some time in 1972 they switched to single wall tops, but I'm not sure when. Both tops have different bolt patterns. Some 1972's have double wall holes, some have single wall holes, and them some of both.
Mint68 is offline   Reply With Quote
Old 01-05-2009, 01:26 AM   #6
CCCC
CCCC's Avatar
Not to hijack this thread, but thanks a lot Mint68. I get the full picture and, even without going out to the garage to look, now know that two of my 72s have double wall tops. The third Blazer came to me with a soft top - so I will need to inspect the rails.
I am thinking about this roof rack for the hunting rig.
CCCC
CCCC
Old 01-05-2009, 10:13 PM   #7
BAD4X4
BAD4X4's Avatar
Ttt
Old 01-06-2009, 05:22 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nice rack
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-06-2009, 08:13 PM   #9
CCCC
CCCC's Avatar
Hello Bad4X4. I'm still trying to decide if I want to punch 4 holes in the roof of a pretty much original second owner rust-free 72 Blazer - not sure. In the meantime if you do not mind - about your K30 trucks - are they both standard wheelbase and what type of bed behind the cabs? A pic or two, maybe?
Thanks, CCCC
CCCC
Old 01-06-2009, 09:24 PM   #10
BAD4X4
BAD4X4's Avatar
Here is a pic of Ol'Blue. It has a Dana 60 front end and a 1-ton full floating 14 bolt in the rear. Both truck's started there life as k-20's. Hope this helps.
Old 01-07-2009, 07:28 AM   #11
vtblazer
vtblazer's Avatar
Mid-week bump for that nice rack ya got.
vtblazer is offline   Reply With Quote
Old 01-07-2009, 09:39 AM   #12
BAD4X4
BAD4X4's Avatar
vt are you stareing at my rack??????
Old 01-07-2009, 10:10 AM   #13
vtblazer
vtblazer's Avatar
Busted...
If you were closer...and I was intending to use a hard top, I'd love to get my hands on a rack like that!
Old 02-04-2009, 12:55 AM   #14
BAD4X4
BAD4X4's Avatar
Bump
